replace shifter cables/linkage
Its pretty easy to do man. There is only one bolt holding them down under the car right by the down pipe. After that. Just pull them off your transmission and disconnect them from inside the car as well. The firewall grommet is a bit of a pain . But even that isn't bad at all. Just pull it and it will pop on its own. Or you can use a flat heat screw driver to push it through the firewall.
The only thing I'm stuck on is figuring out how to get the damned transmission to lock into 4th gear, by releasing the spring assembly. I kept feeling like I was going to break something...
DANRICKARD
Oct 1, 2015 12:08 AM
importkiller
Sep 30, 2015 07:18 PM
