Replacing everything
Ok so after about 2 months of progressively worse cold starts, stft and ltft, stumbling, random knock, missfires when cold starting, and p0301,p0451, p0459, I've decided I want to replace every sensor on this car before I get retuned. So far I have these in mind:
Ac delco # 2133844 #1 wb o2 sensor
Ac delco # 2134254 # 2 o2 sensor
Ac delco # 2134222 MAF sensor
Ac delco # 2141473 P soleniod
Ac delco # 12589440 PCV valve
i have gms1 so I would like to buy both the map and tmap sensors but just the sensors themselves but can't seem to find any that don't come in a kit. I am also going to be getting a new canister in the back and the vent valve. Any thing else i am missing? Maybe a fuel cap? Was also thinking of pulling the head and replacing the intake valves and putting a phenolic spacer in.
Doesn't bother me because those sensors and parts are prone to failing so I wont have to worry about them for a bit. Plus I've also checked all my intercooler connections, intake, bpv, and charge pipes for leaks. As far as the knock sensor, were abouts is it and should I order a new one of those as well?
My valves are gummed up just like everyother lnf roaming the earth but there not that bad yet.
Last edited by Balt_and_Vette; Sep 6, 2012 at 12:12 PM. Reason: Automerged Doublepost
Exhaust Gas Recirculation Valve - ACDelco 214-2230
Fuel Tank Cap - ACDelco GT283
Ya I have cleaned my maf twice now which made it better the first time but second it had no affect. same goes for my lower tmap sensor. They are all cheap anyways so I'm not worried about it. A couple hundred dollars for a little piece of mind and a happy car is very worth it in my eyes.
Nutty, These cars don't have EGR valves.
OP: What have you done to diagnose the misfire on cylinder #1? Whatevers causing that is likely causing your fuel trim issues. Start with the basics of fuel, spark and compression. When does the misfire happen. Is it a hard jolt of a misfire or kind of gradual?
There's hardly a need to replace every sensor you have.
As for the P0451, thats a code for the fuel tank pressure sensor (located on the evap canister). There's a bulletin to install a cover over the sensor to prevent debris intrusion. Simple enough.
The P0459 is for the vent valve... which likely needs to be replaced. Not the canister.
I already swapped everything over yesterday. Not sure which one did the trick but my car is running mint now. Not one misfire or hesitation anywhere. It runs like it did when it was stock.
well they do... I took one out of my car and replaced it with a new one, so.. yeah it does.
I was able to order one, able to take one out of my car and able to put the new one in, so...
^^ I'm sorry, but you either clearly must not know what you're looking at, don't have a lnf or don't know what an egr valve is. Either way you are incorrect. I would love to see a picture of this supposed egr valve you are refering to installed in the car though.
Nutty21, does your "EGR valve" look a little something like this by any chance? Something tells me it probably does..
Ecotec Evap Vent Solenoid 25932573
ACDelco 214-2230 Exhaust Gas Recirculation Valve : Amazon.com : Automotive
It does, here's the link to the one I ordered and replaced, and is on the car running fine.
1) Amazon misinformed you by calling this part an EGR valve
2) you really don't know what an egr valve actually is or what it does if you believed them..
I dont' know. I know what it does and I replaced it and it's in there and working anyway. Part number I pasted originally is still correct anyway.
