Reverse Grinding
Reverse Grinding
So, every now and then when I start my car up and put it in reverse it grinds. Clutch is all the way in, car isn't moving. My driveway is on a good slant and I have a hurst short throw installed.
Any idea's, ya'll?
Any idea's, ya'll?
mine does it once in a while, i have noticed if i slide it into first before reverse it goes in a lil nicer.
^^^haha beat me to it
Mine does it once in a while as well.
The Reverse synchro must not be all that great in these transmissions.
If you put it in 1st at a dead stop and then engage R, you won't ever get a grind because putting it in 1st stops the input shaft from turning.
no synchro in reverse
According to GM and other sources, the F35 most certainly does have a synchronized reverse.
Engaging any gear will stop the input shaft and allow you to engage reverse without grinding.
Japanese cars typically don't have syncrhonized reverse. They save money in engineering so that they can give you a nicer texture on the underside of your dash.
try pressing in the clutch, and holding it for a few 5-6 seconds, then going into reverse. It shouldn't grind. If you just press it in and go to revers, you can get a good grind. I forgot the reasoning exactly for this, i remember reading it on here 3 years ago about the ss/sc... try it.
Actually alot of cars can/will do that. Every one of my manual cars has done that at one point in time. I always get in the habbit of throwing the car in first THEN reverse. Its second nature for me now, and it never grinds
Those were my first thoughts. Clutch grabs/releases in the middle of the pedal... and the trick I learned to check for drag didn't work. Doesn't mean that not still the case though.
If you press your clutch pedal and hold it for a few seconds the shafts/gears in your transmission will wind down in speed once they're decoupled from the engine. Once they slow down a bit they mesh with the synchro more smoothly (since the rotating speed difference between the two isn't as large), and typically won't make any noise.
royce777
Sep 28, 2015 07:11 AM
