Snail_ss build thread
Old 02-04-2017, 11:43 AM
  #451
63 Nova SS's Avatar
Bummer
Old 02-04-2017, 11:50 AM
  #452
Yeah it's sucks, I know I have the power but can't use it. with that said if it is the dp then I'll just go catless
Old 04-10-2017, 07:37 PM
  #453
Well it has been forever but now that I have settled into my new house I have started the tear down of the car I was going to try and get a sedan but I'm just keeping my balt.
Old 04-11-2017, 06:09 AM
  #454
63 Nova SS's Avatar
Have fun and stay motivated.
Old 04-11-2017, 08:04 AM
  #455
Thanks man it has been crazy month 1/2 finally I can start working in the car again . So for now I'm going to do a boost leak test to see why my zfr won't boost past 20 psi also i checked my dp yesterday and my cat looks good nothing is loose and i found the piece thats making noise and vibrating
Old 04-12-2017, 09:11 PM
  #456
63 Nova SS's Avatar
You will get there. I quit working on my cobalt for the short term and am working on my sons old Saab. Over next winter though it will get the parts I have stocked up including the zfr.
Old 04-12-2017, 09:35 PM
  #457
Yeah need to order new gaskets first to remove the turbo apparently it's still leaking a tiny bit of coolant it has a new gasket so not sure why it's leaking. Should be pretty easy to remove once the transmission is out of the car
Old 05-11-2017, 07:14 PM
  #458
Well I haven't gotten very far on the car transmission wise but I finally completed my boost leak tester and i did a boost leak test, I had a pretty big leak on the lower cp @ the tb connection. got that fixed and tightened, I did notice where the maf relocate plate goes it has little bubbles coming out it's not alot, not sure how to get that to seal up perfectly tho any ideas? I did tighten the bolts and it did help a bit.
Now I'm going to put the car back together and test my boost levels and see if that sealed it, Maybe complete my tuning once that's done I can start the swap since I won't be able to tune until the new clutch is broken in and that might take a a few weeks to do
Old 05-18-2017, 10:09 AM
  #459
So update just ordered my stage 1 with fuel lobe cams about to order my meth kit as well
Old 05-18-2017, 10:14 AM
  #460
nice! what meth kit?
as for the leaks not sure if copper gaskets is an option or copper seal spray. leaks blow dude.
Old 05-18-2017, 10:35 AM
  #461
I'm going with the aem 30-3352, the thing is getting enough space to add anything to it lol its behind the turbo no way to get to it thru the top and from behind it's difficult enough just tighten the damn banjo bolt. My plan will be to take the turbo off inspect the threads then put it back on,
I will try logging a bit today just to make sure that I got rid of all my boost leaks once I know it's all good then I'll start tearing her apart again to install the f40 now that I have all the equipment I will be needing.
Old 05-20-2017, 07:35 PM
  #462
63 Nova SS's Avatar
Sounds like you have some work ahead of you.
Old 05-20-2017, 10:29 PM
  #463
Yes I do lol the car will be apart almost completely.
Looking here it seems I have leaks all over the place lol, well found another boost leak, it's next to the map sensor in the cp for some reason it has a hole at that's where everything is escaping from
Old 05-20-2017, 10:33 PM
  #464
Since the car was outside and I haven't taken pics in awhile seemed like a nice place to do so
Old 05-20-2017, 11:34 PM
  #465
heeter_33's Avatar
I love those lights!
Snail_SS (05-20-2017)
Old 05-21-2017, 07:11 AM
  #466
63 Nova SS's Avatar
Car looks nice! Why is there a hole there? Is it bored all the way through into the charge pipe?
Snail_SS (05-21-2017)
Old 05-21-2017, 12:24 PM
  #467
It's hard to tell but I do have air coming out of it so I will say yes, and I have no clue i guess it was blocked with something when I got it from zzp
Old 06-02-2017, 07:57 PM
  #468
Update: I need to get some silicone to use on the lower cp o-ring because it's leaking so that should fix boost leak problems once and for all.
Also received something today
Stg1 cams with fuel lobe
Old 06-02-2017, 08:44 PM
  #469
63 Nova SS's Avatar
Sweeeeeeet. Those cams with fuel line will really give you some options.
You have to have more boost leaks than I've ever heard of.
Old 06-02-2017, 08:48 PM
  #470
Tell me about it they were all in the lower cp I haven't messed with it since I installed it but yeah kinda silly tbh. That's the main reason I haven't done anything to the car
Old 07-18-2017, 02:19 PM
  #471
how are the headlights holding up??
Old 07-18-2017, 02:40 PM
  #472
Really good actually might need tobtake them part to change the color tho
Old 07-18-2017, 06:48 PM
  #473
Vids of car running or it isnt real
Old 07-18-2017, 06:57 PM
  #474
Lol I never said my car wasn't running
Josh@ottp
19
02-12-2016 07:19 AM
JoeJoe228
02-08-2016 06:27 PM
Price_is_Right
02-08-2016 12:16 PM
gilcont9
02-01-2016 05:25 PM
Ryan Matthew Johnson
01-27-2016 02:39 AM
Quick Reply: Snail_ss build thread
