Some new mods, vid inside too
so i could say use that same boost controller on my stock tune, turbo, bypass valve.....? then it would just be a bonus after a tune? just dont turn it any higher than what the car normally boosts now without a tune until then?
^Basically yes. It will be a $300 show piece until you get a tune lol.
Good to know, thanks
Pretty easy if you take your time. The hardest part was getting the cluster out of the little space and out of the car LOL. Not much room between the steering wheel and dash to do it
I used a ruler and sharpie to mark the needle locations, then followed the instructions and everything is good to go! They def look hot at night
Last edited by BYT*SS*TURBO; Mar 22, 2010 at 02:54 PM. Reason: Automerged Doublepost
im just thinkin I plan on a tune so it will be useful. maybe even do both at the same time but i definitely like the idea of being able to turn it down driving in town. i would imagine it helps in fuel economy/driveability, thus its point as far as i can tell.
What really helps the MPG's is the fact you can control the "gain" or "response", depends on what you want to call it. The car is much more tame thru town and on the highway when you dial the gain down, the boost isn't so on/off feeling then! My Avg MPG on the DIC went up a bit after the EBC. I was getting about 23 average, now Im over 26!!! I did just do a long highway trip tho so it should settle in the 25 area. I had a peak of 27.4 on my road trip getting over 325 miles to a tankful
wow that sounds nice. mines sitting around 23-24 on the stock tune. so even getting it up to the 25 area like you say without changing the way i drive would be cool. i keep posting here and then googling stuff...im trying to learn how this works. id like to cut down on the on/off feeling as well. even on the stock boost levels its noticable so i can only imagine how it would be at 25 psi
Just got them on, they ride really good!! Even in the rain, they were pretty awesome, could def feel better grip going side to side. We'll see when it gets dry here how they do against LC at 3K
Last edited by BYT*SS*TURBO; Mar 22, 2010 at 06:57 PM. Reason: Automerged Doublepost
I must have just read it too fast lol.
Def an update first
Ill get a file together for you and send it over tomorrow!
Last edited by BYT*SS*TURBO; Mar 22, 2010 at 08:29 PM. Reason: Automerged Doublepost
.035 pill gets my vote. 24 psi @ 4k in 3rd. Tapers to ~18 psi @ 6500 rpm.
.045 only raises the boost around 1 psi.
You guys have a heavy foot. I get 28 - 30 mpg on my daily commute including stop & go traffic.
Last edited by cmiller8006; Mar 22, 2010 at 09:11 PM. Reason: Automerged Doublepost
i donno if its caz i havent been on in a while or what but i have no idea what this pill is and im really curious now...can sum1 fill me in please
edit: i should note that i just searched so you dont really have to answer this i suppose. im not quite sure i understand it very well yet but im gonna keep looking.
