spec stage 2+ prices...
Old Nov 27, 2010 | 01:06 PM
msfitoy's Avatar
Has anyone been shopping for this clutch? I was wondering who is having a sale on this item...and does anyone know the torque capacity of the stage 2+...Thanks!
Old Nov 27, 2010 | 07:53 PM
raynrishad's Avatar
I just bought one from Turbotech about two weeks ago or so. All in all the total price was a tid bit over 700$ They just had a black friday sale of 10% off everything so you may want to see if that's still happening. So far I'm enjoying the clutch. It engages a LOT sooner than the stock, but puts a lot more pressure on your leg if you hold it in for too long. But on top of the clutch you also need to get a new Throw out Bearing and new flywheel bolts. Thats another 150+
Old Nov 27, 2010 | 07:57 PM
msfitoy's Avatar
Wow...700?! Guess I better start saving...that's nearly 2gs for a clutch...
Old Nov 27, 2010 | 08:23 PM
b00sted06ss's Avatar
cant go cheap on clutches!
Old Nov 27, 2010 | 08:30 PM
TurboTechRacing's Avatar
X2, plus the clutch is only 1/2 the cost, you still have 4-8 hours of labor to install it. You dont want to do it twice, that is why it is good to do a good one first.
Old Nov 27, 2010 | 08:39 PM
Iam Broke's Avatar
It's rated at 437 ft/lbs and holds well, I've been running mine from TTR since last March with the lightweight flywheel.
Old Nov 27, 2010 | 09:19 PM
raynrishad's Avatar
I did all the work on mine except turning the flywheel. Took that to a shop. They don't make shims for our flywheels yet, from what i've heard. When you buy the spec 2+ you have to drill the flywheel pegs to a larger hole 12mm so that the new pegs for the spec 2+ clutch can sit on. They are quite larger. If you don't have a drill press I suggest you have a clutch shop do that as well.
All in all it was about 10 hours of labor total. Woulda been a lot less if I'd had more experiance >.>
Old Nov 27, 2010 | 10:39 PM
Iam Broke's Avatar
^^^^ That's why I went with the matching LW flywheel. No machine shop work needed. Others have left the dowels out altogether but I wouldn't recommend that.
Old Nov 27, 2010 | 11:04 PM
msfitoy's Avatar
Must be inflation...I have a spec 3 clutch installed in my Mini 5 years ago and the part cost me less than 400 (less install)...wow...
Old Nov 27, 2010 | 11:49 PM
raynrishad's Avatar
Hehe, I've got the hook up for flywheel grinding. Not to mention barelly ANYthing had to be taken off of the flywheel. I wouldn't recomend leaing the pins out either.
Different parts for different cars cost different pennies.
Old Nov 27, 2010 | 11:55 PM
msfitoy's Avatar
lol...I expect that but...a Cobalt part costing more than a Mini Cooper (which is made by BMW)?
Old Nov 28, 2010 | 12:01 AM
raynrishad's Avatar
Ha. Call a dealership and ask how much the stock flywheel is. You'll crap yourself.
Old Nov 28, 2010 | 03:20 PM
Shanedude's Avatar
I bought a well priced (450$) spec stage 2 clutch for my supercharged sunfire from Turbo Tech Racing. $1000 alltogether (labour,parts,resurfacing flywheel)
Do research before you buy a lightened flywheel. I've heard it will decrease gas mileage a bit, and makes everyday driving more difficult.
Old Nov 28, 2010 | 03:38 PM
CurrentlyPissed's Avatar
Our transmission is a sweden part anyways.
Old Nov 28, 2010 | 07:56 PM
raynrishad's Avatar
The flywheel says "made in Germany" On it. w00t for german parts.
Old Nov 28, 2010 | 07:57 PM
Iam Broke's Avatar
I have a slightly used stock LNF FW if anyone wants it. PM me.
Old Nov 28, 2010 | 08:19 PM
Yup the tranny is "getrag" which is German.
DarrenGC
Dec 24, 2021 01:55 PM
HEATON
Oct 16, 2015 07:21 PM
nathan112i
Sep 30, 2015 07:12 PM
grampss
Sep 27, 2015 08:51 PM
