Stock Brakes vs Hawk
Old May 31, 2011 | 01:51 PM
Mike08ss/tc's Avatar
Its time to put some brakes on the car again and I dont really know if i want to stay stock or try some Hawk pads. I work at a Gm garage so all my stuff is dirt cheap but i cant get hawk pads cheap.
Stay stock or go with Hawk
Old May 31, 2011 | 01:54 PM
JacBlackSS/TC's Avatar
the hawk hps pads are really nice not that loud and stop pretty good
don't get the hp+ too agreesive for daily driving more of a track brake set up brake wise
Old May 31, 2011 | 02:04 PM
ericgt79's Avatar
uhhh that makes about as much sense as **** on a bull...wtf are track brakes and why would i want to stop less on the street than i would on a track?
my mind is baffled by that one, anyways......
i have hawk pads hp+ and they are AWESOME, after over a year i still have tons of pad left. get them!
Old May 31, 2011 | 02:10 PM
Hawk Performance’s HP Plus brake pad compound is ideal for Autocross and Track Day drivers looking for a high performance race compound that can take the heat of the track and get you home safely without having to change the pads.
The High Performance Street compound offers a higher coefficient of friction over stock brake pads and can provide you 20-40% more stopping power and higher resistance to brake fade than most standard replacement pads. Less fade means you will have a highly durable brake pad with less brake dust.
reading is your friend
Old May 31, 2011 | 02:17 PM
BlueTurbo's Avatar
The funny thing is, he probably doesn't realize he's getting less braking force than his old stock pads...
Old May 31, 2011 | 02:24 PM
oh well can't win them all
but its no way daily driving he can get the hp+s hot enough to stop that was the whole point of my original comment i was going to explain that but decided to educate instead
Old May 31, 2011 | 02:26 PM
BlueTurbo's Avatar
Some people just buy the best/most expensive stuff for their car just because they can, without thinking of implications.
Old May 31, 2011 | 02:36 PM
Wangspeed's Avatar
The stock pads are excellent, but they dust heavily. They are Ferodo HP1000, which is the same compound used in Audi R8, Ferrari 575, Cadillac CTS-V, and probably more.
They're one of the best track friendly stock compounds available. The downside is the dust. People bitch about them not having enough bite, well, press on the god damn pedal harder. Initial bite does not translate to shorter stopping distances.
If you want cars that have annoying initial bite, to get a Toyota. Or switch to some annoyingly grabby pad.
Old May 31, 2011 | 03:19 PM
DirtyBalt09's Avatar
I just out the Hawk HPS on my vehicle and I have to say it is noticeable difference from stock pads. They dust about the same as stock which dust noticeably.
Old May 31, 2011 | 04:08 PM
edwardfaria08ss's Avatar
the dusting part is similar to the stock for u. thats weird
put my HPS's on some drilled and slotted rotors and i hardly ever see any dust on my rims. the old pads the wheel would be black by the end of the week.
Old May 31, 2011 | 04:32 PM
northvibe's Avatar
STOCK!! The stock pads and rotors are great.
PrincessTurbo's Avatar
Was just about to say ..
I've got the R1 Concepts drilled and slotted with the Hawk HPS and they do just fine in daily driving ..
The peddle is more stiff and the pads aren't as "squishy" as the stocks ..
I would say to anyone looking at brakes if your front stock pads are good stick with them and just change the rotors all the way around and the rear pads , make sure the slide pins are lubed with the right grease.
Hawks are more predictable under different conditions and don't really have a variation. They stay consistent.
I've had my HPS pads for 15k with R1 Drilled/slotted rotors .
Pros-
Don't heat up like the stocks under high speeds and continue to deliver stopping power without gumming up, Lower overall brake noise and squeal . Lowers dusting of rims by about 75% .
Cons - Every day driving they don't have the stock feel. Probably won't stop as fast as the stocks under light every day driving conditions on a dry day .. ( stocks suck when heat soaked )
I guess I would rather have a pad that works no matter whats thrown at it VS a pad that only works well in certain conditions . The stock front pad is still very good but not track worthy for long/. They are more "grabby" under normal dry driving.
Yet the HAWK stuff is more consistent under every variable.
Old May 31, 2011 | 04:51 PM
Pros-
have u ever really heated the rotors up. i heard that these rotors can go to **** real fast on a track and that there mainly for show. i have the same r1 set up and there good for street and in the different conditions u were previously mentioning but. for extreme braking the blank rotors with the stock pads were awesome. probably would have been better with the hps as well.
yeah thats what i run hawk pads and the r1 concepts drilled and slotted and i love it
Old May 31, 2011 | 05:15 PM
northvibe's Avatar
you mean you want to stress the rotor and crack the rotor where its drilled? ugh stay away from those things. and the stock pads are better than the hawk ones. But do as you guys wish!
Old May 31, 2011 | 05:31 PM
Wangspeed's Avatar
Pros-
Sorry, but there is a ton of misinformation in your post. I love Hawk products, but you have to understand what you're getting compared to the stock Ferodo HP1000.
Performance:
Stock Ferodo HP1000 > Hawk HP+ > Hawk HPS > Hawk Ceramic
Noise/dust:
Hawk Ceramic > Hawk HPS/Stock > Hawk HP+
Me? I run stock fronts and HPS rears for the street. Cobalt Friction XR1 fronts and HP+ rears for track.
Old May 31, 2011 | 05:49 PM
ronn's Avatar
Stock fronts are the best. Problem is the f$$kn dust! I don't track my car, so I'm putting these ceramics on the fronts very soon. They are not as fade resistent (heat failure) as the stock pads..BUT..for the street and *canyon carving*..they will be just fine. I have ceramics (Wagner thermoquiet) on the rear now and they're bitchin'. NO dust..no noise and stop the car nicely.
Here are the fronts..Power Stop Evolution. They offer rears as well.
I will report impressions etc as soon as I get on in month or two.
Old Jun 1, 2011 | 09:24 AM
BlueTurbo's Avatar
Pros-
You don't know what you're talking about. The stock brakes do not fade at all. After eight AutoX runs and still hold as well as the first.
Old Jun 13, 2011 | 10:19 AM
1Shotwonder's Avatar
EBC?.....anyone give those a try?
Old Jun 13, 2011 | 10:28 AM
Ben.Reilly's Avatar
Couldn't agree more. While they work great when the weather is warm, they are very noisy and don't work well in the snow and rain for the first few miles.
Old Jun 13, 2011 | 11:13 AM
M-Dub's Avatar
Apparently this site has NO idea of the quality of our stock Ferrodo 1000 pads.......
::facepalm::
Old Jun 13, 2011 | 11:15 AM
M-Dub's Avatar
Performance:
Noise/dust:
My appologies Wangspeed didn't see your post YOU DO!
Old Jun 13, 2011 | 11:27 AM
TTNR's Avatar
This thread makes me LOL, post 3 most of all. Go ahead and try a full racing brake pad, I'll giggle when you can't stop at the first red light.
I'll giggle harder when they eat you rotors up in nothing flat.
Old Jun 13, 2011 | 11:28 AM
YelloEye's Avatar
Stock > Hawk > EBC
EBC is crap.
Old Jun 13, 2011 | 11:36 AM
quikdcride's Avatar
1. i was about to get off the wrong exit when i realized i decided to cut back over onto the 2 lane highway but there was a car. there was the v right in front of me, i was going about 80 i nailed the brakes i dont even think abs kicked in but i made it.
2. i was doing about 90 in the right lane and my short left turning lane was coming up. i was on the other side of a tractor trailer. sped up to about 120 got in front of the truck and over, didnt see the two cars at the red light. got on the brakes but i didnt want to slide and came literally 6 inches front rear ending this mini van hard
those are just two instances where i think hps saved my life. i took the stockers off and they were pretty much brand new. still have them. even when my hawks run out i wouldnt even put the stocks back on and im a pretty thrifty guy. i dont usually like to talk up companies but you definatly get what you pay for the hawk hps's are great
so are twm short shifters btw
