Stripped bpv bolt
Old May 3, 2019 | 02:19 PM
roadrunner132's Avatar
Stripped bpv bolt
Years ago I stripped one of the 3 bolts. I have seen a bunch of other people have done this too. I haven't messed with the bpv at all after that. I screwed it in when the turbo was hot. Not a smart idea. It must have had 1 thread left because the bolt finally worked its way out. My question is do you think it will be fine with only 2 bolts? Or is there something you would recommend? I'm sure it will be fine since it's been 2 years but lately I've had that feeling where the bpv seems to lock up and need to be broken free. I have the forge bpv and it's always done that but usually when it's cold... It's quite warm right now. I would be interested in a new turbo anyway but I have almost 80k miles and I don't want to put a tone into it. I have full bolt on. Could I get an upgraded turbo for a max of 1200 in parts? I would like the 257 but I think that would cost more with the parts required. Really I would like to stay under 1000 but I think that's completely undoable. I have heard of people putting a sleeve in the hole but for that much work and money I could just get a new turbo. That's my thought behind it.
Old May 3, 2019 | 03:22 PM
Dude, use the enter button.
That being said with your budget you're looking at a KO4R.
The forge unit needs to be greased for continued operation.
Old May 3, 2019 | 05:19 PM
michael23v's Avatar
I just swapped turbos so I have all the stock parts from my 2010. If you are interested I could sell you whatever you needed. PM me.
Old May 3, 2019 | 08:48 PM
Yeah that's the one turbo everyone says is a huge waste of money though. Super expensive for the tiny gain. But yeah that was a good suggestion. Thank you. Also I always grease it. Like twice a year or more. That's on the outside though. I don't need to take the 3 screws out to grease that.
Old May 5, 2019 | 02:17 PM
tomj77's Avatar
I screwed up a few threads on mine too back in the day, I use a slightly bigger bolt, and I always blue locktighted all 3 to make sure they don't back off.
Old May 6, 2019 | 07:52 AM
So did you just force in a bigger bolt? Do you know the size?
Old May 8, 2019 | 09:19 PM
tomj77's Avatar
nope don't remember size, bugger bolt actually went in easier then I thought it would. just use one with same thread pitch, slightly bigger. I could probably actually check, I do still have the turbo
metroplex
Jul 7, 2019 01:37 PM
KoriCobalt
Jan 19, 2014 07:30 PM
trainplane3
Jun 25, 2013 06:02 PM
tomj77
Nov 26, 2012 10:38 AM
HHRSSouth
Mar 5, 2012 11:20 AM
