Temperature affecting coolant level?
*Update* The Tech's Couldn't find a leak on mine - they did a pressure check and also looked under the oil cap to see if there was any moisture on it. They are gonna replace my coolant reservoir and cap, hopefully whatever is going on is fixed?
It's normal for a little coolant to evaporate out of the system after quite some time, especially in the colder temps which will cause the DIC issue the OP is having.
I agree with the approach of top it up and keep an eye on it (it is a 50/50 mix of coolant and water) and if it drops low again there is a problem somewhere.
My Car was low so i took it to the dealer and that only turned around and told
Menthey toped it up 250ml what is the issue with this engine? The 2009'lnf engines have a recall about missinG coolant. WhAtS tHe DeAl???
Iceberg
Sep 29, 2015 12:33 PM
