TMPS Issues
Old Jun 27, 2009 | 01:58 PM
Jbernal4368's Avatar
TMPS Issues
Ok, It has happened 4 times already.... I will be driving down the highway then all of a sudden, I will get a TPMS light and service sensor soon message in the DIC...
What is going on with my car? Any ideas? Anybody have this happen to their TC?
Last edited by Jbernal4368; Jun 27, 2009 at 01:58 PM. Reason: Automerged Doublepost
Old Jun 27, 2009 | 04:04 PM
northvibe's Avatar
have you checked each tire pressure? either one of the tmps sensors is cracked or bad or the receiver part is messed up. your under warranty bring it in.
Old Jun 27, 2009 | 09:57 PM
thats what i plan on doing, but it only happens once in a while
and they are all set to 32 psi
Old Jun 27, 2009 | 10:49 PM
northvibe's Avatar
Can you cycle through the info and see if 1 tire was off or not regstering?
Old Jun 28, 2009 | 08:41 AM
i have, and everytime that this happens, its a different tire
Old Jun 28, 2009 | 08:48 AM
yel-low's Avatar
and they are all at 32 psi because if the tires get to high in pressure then they will go off to if your car doesnt have nitrogen in the tires you get alot of flucation in pressure i work at a dealer and we tell them to get nitrogen in the tires and if keeps happening then we replace the faulty sensor
also do you ever have a problenm with your key fob loosing range
Old Jun 28, 2009 | 05:00 PM
Stamina's Avatar
Are you rotating the tires each time it happens?
On a serious note, either your TPMS system in your car needs to get checked then, or every time you take your car in and they check the sensors they really are not putting them all back on the same way and then reprogram your TPMS system. If that's the case, then it's the sensor in the tire.
To the other posts: It doesn't say low pressure. It just says service sensor. It'll say low pressure on the DIC instead if it's a low pressure reading. (Not sure if there's such thing as a high pressure message)
Tupp
Sep 30, 2015 08:18 PM
yellow dragon
Sep 28, 2015 09:49 PM
SlowSaturn
Sep 28, 2015 11:03 AM
