Transaxle options
::hugs his srtc car::
the max rated trq capacity of the lsj tranny is 258.
if gm is going to do the staged upgrades like they did for the lsj on the lnf. the transmission will have to be beefier to handle it. small turbo = torque
The f40 6-speed is the GTP G6 trans lifted from Saab . Its been around for quite awhile .
Here's a little info
Its rated for 295 lbs/ft . Not too much more than the F35 . I dont put too much faith in those #'s though . The getrag trans is only rated for 170 tq and they can handle a ridiculous amount of power . I looked into the F40 before , Ive never seen any mention of it having a LSD in the G6 or the 9-3 . This trans is also used in the Opel Astra OPC ( VXr ) in Europe and is available there with a LSD .
Go to car-part.com and search for a manual trans in 2006 G6 . There several low mile or 0 mile F-40's for under 800 bucks
Yes , you missed the logic there . Our trans comes unmodified out of the 9-3 , and in the 9-3 , the optional 6-speed bolts up to the same engine . I dont have any sizes though of the case . Better question would be , will it clear the driverside rail of the Cobalt engine cradle .
FYI. It is also 352mm wide. Time to go out to your car and measure.
The Fxx nomenclature is nothing more than a reference to the transaxle's torque rating iirc in Newton*Meters (350Nm-f35, 400Nm-f40, etc).
so what would i do as far as clutch wise. get a clutch for a ss/sc or saab 9-3. essentially there the same as stated above. but is there clutch flywheel gonna be the same. im searchin the junkyards for a f40 to buy one and finally figure out if this will work
thats what i figured just trying to make sure. has anyone tried this or would i be the first one to attempt it. and before anyone says anything dont worry bout the mechanical ****. ik what im doing and also my best friend just had a lift installed in his "barn". makes things so much easier
Should be no more difficult than changing out the clutch in our car. Just will be bolting a different tranny in when you go putting stuff back together.
Be nice if we could get pics of the MWL trans to compare.
Thanks for the correction Whitt . I will do some more digging on the MWL option code . Its possibly a new FWD version of the MU9 then , as the LNF will be going into the next gen 9-3 and Astra . I have access to GM Dealer world , so I'll see what I can pull up next week sometime .
importkiller
Sep 30, 2015 07:18 PM
Iceberg
Sep 29, 2015 12:33 PM
