TTR Solid Engine Mount w/Rotated Trans Mounts?
So I've had this TTR Solid Engine mount lying around for a while now, it's finally nicer out and I can work on my car. So here's a question I never really got an answer to. Will there be any issues running it with OTTP rotated trans mounts? What should I do?
i know powell knows best but i run the setp you describe, the TTR isnt as solid as ppl think. the key is to have all the mounts "loose" then torque them after a short drive to allow it to find the proper alignment'
i didnt like the engine rock the stock upper MM gave me on and off throttle
If Japeatr has made it work then you can too. I dont recommend it, but J knows best as he has done it.
check the f23 mount thread that is current on the board for more information.
patooyee
Oct 1, 2015 01:07 PM
