TTR Solid Engine Mount w/Rotated Trans Mounts?
Old Mar 14, 2013 | 05:51 PM
Aleksey's Avatar
So I've had this TTR Solid Engine mount lying around for a while now, it's finally nicer out and I can work on my car. So here's a question I never really got an answer to. Will there be any issues running it with OTTP rotated trans mounts? What should I do?
Old Mar 14, 2013 | 06:13 PM
Powell Race Parts's Avatar
if you use it you will risk breaking something. please refer to the threads on this forum explaining rotation and then you will understand why this is a risk. thanks
Old Mar 14, 2013 | 06:44 PM
PsychoGenius's Avatar
After a quick search< i didnt see anything on the first 3 pages of results that might explain this. I am assuming because the rotated mounts are not meant to be used with a solid engine mount?
Old Mar 14, 2013 | 06:46 PM
JapEatr's Avatar
South Central *********
i know powell knows best but i run the setp you describe, the TTR isnt as solid as ppl think. the key is to have all the mounts "loose" then torque them after a short drive to allow it to find the proper alignment'
i didnt like the engine rock the stock upper MM gave me on and off throttle
Old Mar 14, 2013 | 07:02 PM
If Japeatr has made it work then you can too. I dont recommend it, but J knows best as he has done it.
check the f23 mount thread that is current on the board for more information.
Jan 12, 2016 12:01 AM
OrangeCoba
Oct 1, 2015 10:00 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
