Turbo surge, wut is it??
Old Nov 6, 2010 | 10:18 PM
robk's Avatar
Ok just like the title says. Ive search on here about it w everyone talking about it and everything and im just finding the "how to fix" it stuff. But im wanting to know wut it is exactlly, and how can i pay attention to the car to see if im getting it or not. I know this seems like a newb question, and yes this is my first turbo car, so lease be gentle on the flamming Thanks in advance
robk
Old Nov 6, 2010 | 10:26 PM
USMCFieldMP's Avatar
Rattlesnake Race Shop
Go on YouTube and type in "Compressor Surge".
Thousands of videos.
Basically... you make boost... but there is more air moving than what the motor demands... and it only has one place to go... back out the way it came in (aka out the turbo inlet). This can be caused by a few different things... most common ones are the Throttle Body Butterfly closing... and the BOV not opening, not opening enough, or not opening soon enough... or by hitting too much boost before the throttle body is fully opened. There are a few other reasons.
That's a real rough... basic description.
Old Nov 6, 2010 | 10:45 PM
AndrewSS/TC's Avatar
Someone needs to write up a sticky about this subject.
Old Nov 6, 2010 | 11:37 PM
Or people need to [/LAZY] and use Google. Compressor Surge isn't something that only Cobalt's experience.
Old Nov 6, 2010 | 11:47 PM
That too, a lot of these have been popping up lately
Old Nov 7, 2010 | 11:17 PM
Matt M's Avatar
Compressor surge is a rapid decelleration of the compressor wheel that takes place when there is not enough energy being harnessed by the exhaust wheel to drive the compressor wheel at the current speed and pressure ratio.
Old Nov 7, 2010 | 11:22 PM
vahdyx's Avatar
YouTube - chipmunks turbo compressor surge bov
Old Nov 7, 2010 | 11:27 PM
exiged's Avatar
in simplest terms the air goes back into the turbo.
sounds like this:
YouTube - Compressor surge?
Old Nov 8, 2010 | 01:53 PM
vahdyx's Avatar
We should sticky this. I support the comment above.
Old Nov 8, 2010 | 02:11 PM
CudaJoe's Avatar
no seriously listen to this youtube video.
http://www.youtube.com/watch?v=bNiLw4PjoQA
Old Nov 8, 2010 | 08:29 PM
Dinglefitz's Avatar
Retarded. Thanks for wasting my time.
Old Nov 8, 2010 | 10:07 PM
vahdyx's Avatar
Fun with real fluttering at the end of the video
Old Nov 9, 2010 | 12:11 AM
importkiller's Avatar
Yeah, turbo or compressor surge bad, BPV flutter not as bad but pretty damn common on these cars.
Old Nov 9, 2010 | 01:22 PM
robk's Avatar
Ok so i watch those vids and are you refering to the noise after the blow-off valve or the way the blow-off valve is making the noise? Thanks for the help on this guys
robk
Old Nov 12, 2010 | 07:49 AM
bogalusahondakiller's Avatar
I get surge. But it's only sometimes when I nls but that's it
Old Nov 12, 2010 | 08:01 AM
CudaJoe's Avatar
I used to get Surge. But then Coca-Cola stopped making it.
Old Nov 12, 2010 | 08:45 AM
RoadconeTuning's Avatar
from what ive seen i got it a lot from the TB not opening enough for the amount of boost being made... the stock BPV is a piece of crap and get stuck closed longer than it should since they decided to put a steel slug in the middle of a piece of rubber in an aluminum housing and not expect everything to expand at different rates... my car has ZERO flutter now with the Forge BPV and as i've always heard i hear a single solid deep chirp if i run out 2nd or third and clutch it at 5500 or so but i blame that on insufficient sizing on the bpv openings on the turbo itself.
basically keep the stock airbox and get a forge bpv and you'll be good... forge bpv may be 150 bucks but when you see the quality of the part you'll wonder how/why GM is charging 60 bucks or whatever for the stock replacement...
Old Nov 12, 2010 | 09:26 AM
sebbie16's Avatar
Watching those videos shattered my dreams... i always thought it was just a cool sounding BOV. Oh well... knowledge is power especially since this is my first turbo car.
Old Nov 12, 2010 | 03:04 PM
robk's Avatar
Road- Where did you purchase your forged valve at?
Sebbie- i was right there with ya on this one, lmao!!
Thanks everybody for the help on this
robk
Supercharged06SS
Dec 11, 2022 04:47 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
patooyee
Oct 15, 2015 05:11 PM
maliki778
Oct 1, 2015 07:39 PM
