Vacuum Problem
Old Sep 24, 2011 | 08:20 AM
steven2008ss's Avatar
Vacuum Problem
Yea, sometimes when I am at idle I will notice that Vacuum being at 12hg-14hg then it just fixes it self?
Anybody know the cause of this?
I thought BPV at first, but if it is not that I am not going to waste my money buying it, if it is really not needed.
Old Sep 24, 2011 | 11:33 AM
no one?
Old Sep 24, 2011 | 02:31 PM
FRQ FLYR's Avatar
Maybe an intermittent vac leak? Not sure the bpv comes in to play at idle.
Old Sep 24, 2011 | 02:37 PM
zrated89's Avatar
alot of factors will have an impact on the vacuum readings. different loads on the car, etc. If it fixes itself then its doing what its supposed to
Old Sep 24, 2011 | 11:10 PM
Zrated can you explain like what
Old Sep 25, 2011 | 08:21 AM
Iam Broke's Avatar
Purge solenoid opening & closing at idle with a possible vac leak in the system. Unplug the connector on the purge solenoid for a day or two to see if it goes away. Possible CEL will result though.
Old Sep 25, 2011 | 11:11 AM
zrated89's Avatar
or u can use a scanner and manually close the purge solenoid and vent solenoid and do a smoke test. Most likely youd have to have a shop do it though. And if your purge solenoid is bad it will typically on our cars result in a po496. Mine went bad and i didnt really notice any huge fluctuation in the vacuum reading though. Does the car have any cels? Lean code ect
Old Sep 25, 2011 | 11:15 AM
zrated89's Avatar
for instance like when you turn your ac on, it creates a load on the engine resulting in lower readings. Or when you have to brake hard and deplete the vacuum booster. There are alot of things that will affect vacuum readings just like boost readings. Honestly if you dont have a CEL on and the car doesnt have any drivability issues i wouldnt worry about it just yet. Just noticed you are a TC you have alot of other things on your car than an SC that can attribute to your readings. Just monitor it and see if any cels come up and go from there
turbochargedss2012
Sep 20, 2023 12:17 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
yellow dragon
Sep 28, 2015 09:49 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
