Vacuum while cruising?
Jus wonderin What everybody's vacuum is at while jus cruisin..
Not when you're gettin on it or nuthin, jus cruisin like highway speeds or watever..
I'm trifecta Tuned with that Forge BPV an Green spring an usually I'm around 15hg an 20-21hg when im on the clutch,18 when the clutch is in. When I had the yellow spring, it seemed like i was usually sittin around 16-18 hg while off the clutch
10 hg at freeway speeds
15 hg at city speeds
20-21 hg when coasting (no throttle but still in gear)
20-21 hg when stopped with clutch in or idling
18 hg when stopped with a/c on
30 PSI
But really, I sit right around 10 in/hg while cruising steady. Sometimes at higher highway speed while just cruising on a really flat piece of road and really light on the throttle I see 15ish.
Idle warmed up is 20 in/hg
Decel in gear is about 21-21 in/hg
AC on is about 17-18 in/hg
30 PSI
