View Poll Results: When did you first notice rotor scoring/grinding? If no issue, how many mi on SS/TC?
Problem @ 1-5000 mi
136
25.61%
Problem @ 5001-10000 mi
83
15.63%
Problem @ 10001-15000 mi
40
7.53%
Problem @ 15001+ mi
39
7.34%
No Problem @ 1-5000 mi
43
8.10%
No Problem @ 5001-10000 mi
24
4.52%
No Problem @ 10001-15000 mi
18
3.39%
No Problem @ 15001+ mi
30
5.65%
Voted just to see results
118
22.22%
Voters: 531. You may not vote on this poll
Wearing rear brakes? Come in
Old Jan 5, 2010 | 12:43 PM
  #451
09silverSSS's Avatar
Originally Posted by beast10007
Well I went to another dealership today and loved it. I went to a small chevy dealership and told them about my rear breaks and how almost everyone is haveing a problem. After waiting for 30mins to see if they could do anything about it they told me the same thing all the other dealerships say sorry we cant do anything about it. I asked to talk to the head guy he looked at my rotors and said hey we cant buy you new ones but we can fix them.....they turned them took another hour and bang there fixed.
So it took an hour and a half and they fixed it for free....I hope this is the last time I have a problem with my breaks.
Because I went to a smaller dealership they let me walk around and look under my car.
If you guys are having a hard time getting them fixed I would try a smaller dealership....I had to drive 30 mins.
Also they said that the rear complaint reports cant help
My dealership said that they have special accounts where they can use GM money to fix or replace parts like this as an act of goodwill.
Did they replace your pads or just turn your rotors?
I believe GM has a script that the dealerships read off trying to explain that there is no defect and that the rear brakes are naturally a high wear item. LOL. At least that is what they said to me.
Old Jan 5, 2010 | 01:37 PM
  #452
Billdayton's Avatar
Get you caliper slide pins lubed! I had my rear rotors turned at 4600 miles at my cost, but CAC gave me a letter worth $100 credit on service. Then, at 8000 miles, the dealer replaced pads & rotors, and lubed the slide pins (they were dry). At 12000 miles, no wear is apparent.
Bill Dayton
95 Corvette, 09 Cobalt SS
Old Jan 5, 2010 | 09:18 PM
  #453
beast10007's Avatar
Yea I only got my rotors turned they did not replace the pads but what ever its a start.
Umm I dont think they did anything about the caliper slide pins.
Do they take the pins out to take the rotors off.
Old Jan 5, 2010 | 10:46 PM
  #454
Urban Rogue's Avatar
sigh. 25,000K and my rear rotors and pads are SHOT. grinding metal.
Fronts still have a LOT of pad left.
Sigh great breaks ya used in the rear GM
Old Jan 5, 2010 | 11:33 PM
  #455
Billdayton's Avatar
No, they don't. It's not a real hard job, look up pad replacement on this site or Autozone, etc.
Old Jan 6, 2010 | 02:52 PM
  #456
rukkee's Avatar
Just had new rotor's and pads put on 7000 miles . They greased the pins and adjusted the Ebrake cable because something was hanging up in there. I know nothing was hanging enough to feel it in the car.It coasted fine and never felt like there was any resistance going down the road. Would roll in neutral on just a slight grade.
The brake warranty is 12 month 12K miles on wearable items like brakes . People who have over 25K miles and are trying to get brakes warrantied are gunna be disappointed 9 times out of 10 . If i had 25K .... I would have just did them as maintenance and bought aftermarket parts.
Old Jan 6, 2010 | 03:39 PM
  #457
I got mine replaced at almost 17k miles.
Thankfully I have a good dealership that will work with me.
I just hope the new rotors/pads they put on the rear will last longer.
If they don't then I'm going all aftermarket parts.
Old Jan 6, 2010 | 03:45 PM
  #458
Sweetsandman's Avatar
I figured I'd finally post in this after a good amount of time...but I just clicked over 15,000 miles and have no uneven or weird wear patterns...must've just been a bad batch. I've also noticed that my car never had any signs of the Oil leak from th valve cover either...Guess I got lucky
Old Mar 4, 2010 | 05:06 AM
  #459
Jaim's Avatar
15,000
Old Mar 5, 2010 | 01:27 AM
  #460
Cptnsweet's Avatar
the dealership lubed my brakes and sanded the rotors on the 1 time i took it in and the 2nd time they replaced the left rear caliper and said that the TC brakes are supposed to make some squeak/grind noise and to pretty much just get over it
Old Apr 3, 2010 | 09:10 PM
  #461
BlueSS-supercharged's Avatar
I tried searching but came up with nothing. I traded my ss/sc awhile ago but posting this for my older lazy brother who doesnt want to look up his username and pass. He has an 09 ss/tc and we did his front brakes today. Hes been having a wicked vibration and he has bad wear on his rear rotors. For some reason we just replaced the front pads (afterwords thought this wouldnt do much). But my question is basicly the long pins that go through the front calipers and pads need to be punched out? I found a g35 youtoob video of basicly the same brakes. But my second thought is are alot of other people having trouble with there rear rotors wearing that bad? I mean damn in both our first ss/sc cobalts we had to replace both front pads and rotors within the 15xxx mark. He only has 8xxx on his. Any thoughts Il try to check this thread out again. Man I miss this site
Old May 24, 2010 | 12:57 PM
  #462
VE6SDW's Avatar
Rear inner pads hit metal to metal at about 4,000km. The outside pads and rotor surface looked very good. The dealer put on new rotors, pads, calipers, and pins. All under warranty. The slide pins where not available with out the calipers at that time, so they replaced the calipers to get the pins.
I now have 52,000km with no brake issues.
Old Aug 17, 2010 | 09:43 AM
  #463
vahdyx's Avatar
I noticed at 3500 Miles and I'm taking it in today to get looked at. What should I say to them?
Old Aug 17, 2010 | 09:34 PM
  #464
budz1065's Avatar
After reading all the brake threads I had my best buddy (a GM mechanic) lube all the pins on my rear calipers. I did it the day I brought it home. hope it works
Old Aug 17, 2010 | 09:47 PM
  #465
Cobalt_Daddy's Avatar
Originally Posted by krispy
Ok, so I think I figured out the problem with my brakes. It wasn't quite what I was expecting. When I felt the what I thought were the pads in the rear they felt extremely low. However, that was just an assumption because I couldn't see them. Upon removing the wheels and checking the brakes I noticed a feature on the rear passenger caliper mounting brackets that is colliding with the rotor and is making a groove in the rotor. This would explain the grooves in the passenger rotor and the grinding noise I hear.
On the driver side the matching feature is not contacting the rotor. There is a small groove in the rotor but I don't see what exactly is causing it.
The pads on both sides actually are very equal in material left so I definitely was wrong about that. At least I did find a problem so I know that I'm not going crazy. Its very easy to see why the dealer missed it to. I don't think they removed the wheel and looked at it on a lift. To see the feature on the bracket the wheel needs to be removed and you need to be looking from the top.
Passenger rear outer rotor
Passenger rear inner rotor
Driver rear inner rotor
Driver rear through caliper (pad material check)
Driver rear outer rotor
Mine looked alot worse than that.. Just had rear pads and rotors replaced under warranty
Old Aug 18, 2010 | 10:04 AM
  #466
vahdyx's Avatar
Well they machined my rotors and didn't replace anything, I guess I'll bring it back when it has 10k miles. It has 3600 right now.
Old Aug 19, 2010 | 01:36 AM
  #467
steven2008ss's Avatar
Mine were metal to metal at 12K but then again could have been my fault, ive put new brakes on back in..umm...hmmm...March? and still no problems, done about 8K miles
Old Sep 1, 2010 | 09:14 AM
  #468
Medicsstc's Avatar
Well gm has already replaced both of myrear calipers due to my e brake not working now at 16500 it started with the issue u all r having I'm now at 17560 and I stoped by and asked and they said they will look at it but it probably won't be under warenty so I looked around at all the auto zones and pep boys and they don't have parts for it yet so what the Fu@k do I do
Old Sep 2, 2010 | 04:14 PM
  #469
svt's Avatar
svt
Rear brakes failed at 22k... sounds like I've got a lot more out of them than anybody else.
Old Sep 2, 2010 | 08:18 PM
  #470
that's when mine started to grind..
Last edited by Cobalt_Daddy; Sep 2, 2010 at 08:18 PM. Reason: Automerged Doublepost
Old Sep 3, 2010 | 12:23 AM
  #471
ronn's Avatar
Just posted this on the rear brakes file thread...I'll reference it here too:
https://www.cobaltss.net/forums/5205515-post502.html
Old Sep 3, 2010 | 12:50 AM
  #472
SSlobalt's Avatar
Can you post a pic of your caliper? If your pins are covered, you have a different caliper. Notice the caliper slides below, which definitely have no boot.
Old Sep 3, 2010 | 02:35 AM
  #473
ronn's Avatar
Ok looks the same..I was referring to cover on outside. The pin in your pic looks pretty clean and so did mine.
Here's another pic shown in another post here. The poster was showing the problems with his rotors, but the PIN looks damn clean! Here it is again:
Old Sep 3, 2010 | 10:30 AM
  #474
SSlobalt's Avatar
I keep mine clean, now, but it's a pain. Keeping the slides cleaned and greased has cured my issues (emergency brake actually works now and no grinding noise), but it gets old. I need to put a boot on them like someone else on here did. The scoring still occurs, but I guess that's more a function of the pads.
Old Sep 3, 2010 | 06:00 PM
  #475
ronn's Avatar
I'm gonna switch to HPS or EBC pads with center gooves. Perhaps **** is accumulating under the pads? Like I said..I get on my brakes hard regularly. I also use the handbrake when I come to stop lights..instead of keeping my foot on the brake. Ya I know it's a crazy habbit of mine, I try to preserve the brake lights..and it works. Never have to replace em that way. Could be that that practice is actually keeping the rears clean, since someone said it's related to the emergency brake sticking? My rears are really in very good shape and I have STOCK everything right now.
