Weird Problem
Old Feb 11, 2010 | 04:57 PM
murrant22's Avatar
Weird Problem
So i have had my dash trim apart to be painted, and just haven't put it back for awhile, and its still not together. This also happened to me before when i had it apart as well, the backlighting behind the radio, and buttons and gauge cluster haven't been lighting up.. Has this happened to anyone else? When i put my dash back together before it worked.. So i have no idea what it could be...
Old Feb 11, 2010 | 05:08 PM
SSlobalt's Avatar
It has to have something to do with the dimmer switch next to your fog lamp button.
Old Feb 11, 2010 | 05:12 PM
murrant22's Avatar
I made sure it was hooked up and everything, and i've tried to turn it but nothing. Maybe once i hook everything else back up?
Old Feb 11, 2010 | 06:48 PM
SSlobalt's Avatar
Have you actually disconnected some wiring? If so, it might work when you get everything hooked back up. Some of that stuff is in series. I'd have to see a schematic to know for sure. It's possible that the switch was damaged at some point, though. Do you have a multimeter?
Old Feb 11, 2010 | 07:11 PM
Iam Broke's Avatar
Sounds like you are missing a ground connection someplace. Are all the screws back in the pieces? Look for a wire that may have supposed to go under a screw for ground. Just my 2cents, no experience on these dash pieces.
Old Feb 11, 2010 | 07:49 PM
Laser_Blue's Avatar
That happened to me wen I was goin to work one night and it was a fuse I think it was the daytime running light.
turbochargedss2012
Sep 20, 2023 12:17 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
yellow dragon
Sep 28, 2015 09:49 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
