What is the diameter of the stock catback on an SS/TC?
Member on here had it I.D.'d when he cut the TC 3 bolt flange off to put a 2 bolt flange for his LSJ
Look where you're at and try again
And stock LSJ DP is 2.75 and tapers down to 2.5 at the end of it.
The GMPP exhausts are 2.25 and post gains on cars...there's more to exhaust than size
Must be true if it's on the internet
Last edited by steddy2112; Jun 21, 2010 at 01:25 AM. Reason: Automerged Doublepost
http://www.modernperformance.com/081...c-473_599.html
Most assuredly seems to me that there is no aftermarket 2-1/2" catbacks/downpipes...
That's how the smaller GMPP exhaust shows gains on the L61/LE5/LSJ cars.
Stock exhaust on the LNF is real good, but it doesn't hurt to throw on a 3" exhaust...you're not going to see much gain if any at all.
you most certainly are going to see gains from a mandrel bent 3" system aft the headpipe;
any restriction removed from the car's exhaust is going to allow the engine to breathe better;
I haven't a clue why you would think that you would see nominal at best gain from upgrading the exhaust system.
umm keeping in mind that this is in the LNF sub-forum;
https://www.cobaltss.net/forums/supporting-vendor-deals-group-purchases-133/agency-power-catback-exhaust-system-cobalt-ss-tc-209066/
There is 1 2.5" catback for LNF's
https://www.cobaltss.net/forums/showthread.php?t=209066
Ok, I'm proven wrong on that point.
smaller OD will help low rpm flow - but once rpm's are brought past the point of gain, it then becomes a power hindrance - because of the increased back pressure...
at least that's how I've understood it.
imho the stock head pipe blows goats.
Theres a reason adding an aftermarket exhaust doesn't net very much power on the stock turbo, maybe
5whp if your lucky. But if some of you want to be stubborn and drop a lot of cash on a full after market exhaust more power to you. It would be cheaper for you to have either a different resonator or muffler welded on at a muffler shop.
Theres dyno numbers floating around somewhere with the difference between the factory exhaust vs. bolting on an aftermarket one.
I personally did an apple to apple comparison a while back between the stock 2.5" exhaust and an aftermarket 3" on a dynojet dyno.. The ONLY thing that made any difference in whp numbers was swapping out the stock dp (in this case it was catless.. I didn't have a aftermarket catted dp to compare).
Unless you are upgrading to a larger turbo setup, or just want/like the sound of the 3" exhaust (which sounds sweet on our cars btw), save your money and put it elsewhere. You just won't see the gains from a 3" catback alone
Sometimes automakers will keep an exhaust just a bit on the small side and/or shape it a certain way to maximize the Scavenging Effect.
Basically, while cruising the air leaving the exhaust leaves in pulses and has a low pressure area behind it as soon as it leaves. By creating a high-speed flow of exhaust (such as with a non-3" exhaust), it "sucks" out the extra exhaust left in the cylinder "for free", leaving room for more fresh air and enhancing cruising efficiency. This is part of the reason that you increase cam overlap while cruising.
When you want more power, then you decrease cam overlap a bit and increase the exhaust size, because then you're going for flow and cylinder pressure.
