What rpm should i reach full boost?
Old Mar 27, 2012 | 09:11 PM
kzak104's Avatar
just wondering what rpm i should be at full boost? also i have a stupid kpa boost guage so what "kpa" should i be reaching? is it possible to switch the guage for a standard american one? im in so i was just wondering.
thanks
Old Mar 28, 2012 | 08:05 AM
Martel18SS's Avatar
What kind of tune do you have? Stock? GMS1? Trifecta/HPT? 103 kPa = 15 psi (usual stock boost), 137 kPa = 20 psi (usual GMS1 boost).
Old Mar 28, 2012 | 08:43 PM
kzak104's Avatar
im stock, i seem to only be hitting between 40 and 50 kpa... whether i floor it or not.
Old Mar 28, 2012 | 08:49 PM
user 72239's Avatar
There could be a multitude of problems causing that.
1.Boost leak
2. Open/bad Bypass Valve
3. PCM limiting it, i had that problem boosting to only 7 psi and the only fix was to unplug my battery and then let it sit for 10 mins, then plugging it back in.
Old Mar 28, 2012 | 08:50 PM
kzak104's Avatar
well i bought the car a week ago so im just going to head to the dealer and have them look at it. its 10 degrees Celsius, i hear that the car will only boost to what it needs to make 260hp, could this be why its only getting to 50kpa?
Old Mar 28, 2012 | 09:20 PM
slapbetcommissioner's Avatar
thanks
These are plug and play so find an LNF boost guage (30psi) and just unplug your factory and plug in your replacement factory
Old Mar 28, 2012 | 09:51 PM
kzak104's Avatar
alright thanks, do i have to pull the pillar off to get it out or do they just pop in and out?
Old Mar 29, 2012 | 08:08 AM
user 72239's Avatar
you have to pull the pillar.
Old Mar 29, 2012 | 12:35 PM
G Speed's Avatar
nope... maybe if it was -40... then yes....
Old Mar 30, 2012 | 12:17 AM
kzak104's Avatar
ha, thats why i thought, thanks for the info guys.
Old Mar 30, 2012 | 12:29 AM
StruttinSoul's Avatar
Hmmm.... Langley wait a second. Did you buy your car from Duek? Is it bluee 2009 ss?
46k kms?
Last edited by StruttinSoul; Mar 30, 2012 at 12:29 AM. Reason: Automerged Doublepost
Old Mar 30, 2012 | 02:32 AM
kzak104's Avatar
i bought from dueck blue but it has 22000k
Old Mar 30, 2012 | 05:38 AM
CudaJoe's Avatar
I would say thats not right for what you should be boosting. No CELs?
Old Mar 30, 2012 | 06:59 PM
kzak104's Avatar
it got up to 80 today, but its raining hard and my car gets litte to not traction when its wet out, so maybe it worked itself out.
Old Mar 30, 2012 | 07:05 PM
BlackLsCoupe's Avatar
are you boosting with a cold block? my car when cold wont boost past 7psi. but once warm its 15psi. but now i got GMS1.
Old Mar 30, 2012 | 07:47 PM
ChevyGuySS's Avatar
Im having the same problem, its because im over boosting without a tune and its going to 20 psi and if it stays there for about 10 seconds, the ecu cuts the boost down to 4-7 and wont go past that. its an over boosting code. wont set a CEL but turning your car off and back on might fix it, if you have a code reader check it
Old Mar 30, 2012 | 08:38 PM
kzak104's Avatar
i never drive hard while my engine is cold. ill look into the code. thanks.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
OrangeCoba
Oct 1, 2015 10:00 PM
SSLOW06
Oct 1, 2015 07:21 PM
dieGone
Oct 1, 2015 06:27 PM
