what wire do i tap into for 09 ss tach pickup
Old Feb 8, 2009 | 10:32 AM
09yelcobaltss's Avatar
installing a shift light which wire do i tap the green wire into to pick up the tach pickup
Old Feb 8, 2009 | 01:37 PM
MaxVQ35DE's Avatar
i dont know that anyone with a Balt TC has done one (we dont really need one with NLS), check the HHR forums
Old Feb 8, 2009 | 01:44 PM
redcomet303's Avatar
I want to know this too because All I ever hear is how there is no up top power.
Mine pulls all the way to the redline and wants to go further I never feel a loss of power.
then agian I am untuned.
Old Feb 8, 2009 | 02:48 PM
BowTieTillIdie's Avatar
Use a Quick Connect 3m Conector so you do not have to cut into wire harness for the Injector on the cyclinder closest to the left.
It is the brown wire I think
I have a Shift light because I like to set it at a certain RPM's for launching and also I like to set it to a certain RPM for when some one else drives it so they aren't bouncing it off the rev limiter all the time to get used to it ... (girls)
Old Feb 8, 2009 | 03:41 PM
rocketpunch1221's Avatar
There is a great post about a raptor shift light install with lots of info on wiring.
search "shift light wiring"
Old Feb 8, 2009 | 05:33 PM
i tryed almost every wire going tot he coils lol .. non worked my shift light has the setting for 4 6 and 8 cycl but not for 1 cyl could this be the problem do i need a new shift light or is there a way to make it work
Old Feb 8, 2009 | 07:02 PM
It takes a while but if I remember correctly I had to set mine to the default GM mode Cylider 1 https://www.cobaltss.net/forums/show...t+light+wiring .. Set it for 1.5 k rpms to test so your not revving it for no reason ...
Old Feb 10, 2009 | 01:15 AM
cobalt85691's Avatar
i have an 08 ss tc i installed a shift light in mine to the purple wire on coil pack 1 all the way on the left on the passenger side you can pm me for any questions
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
dennis69
Oct 20, 2015 07:39 AM
goaliemo
Sep 28, 2015 01:37 PM
jmelton327
Sep 26, 2015 10:04 PM
