where to get billet oil pump gears?
Hello,
After much searching I'm coming up empty on finding billet oil pump gears. There are many references to Bates Engineering, but from what I can tell they don't exist anymore. Is there an alternative?
Daniel
Daniel
Anyone spending a consecutive amount of time above 8k should have hardened oil pump gears, not billet ones.
Also the expansion issue of the gears seems to have been atributed to the stpck balancer, so those on ATIs should be fine
These?
Part Details JP0972
Part Details JP0972
Thanks Andrew. It's odd that the only place to find these gears is in Canada...
tomj77, Bates gears are mentioned in the ecotec build book from GM and there are a couple cases reported of failed gears. It sounds like cheap insurance to me.
Daniel
Daniel
Example (from this forum) just for reference: https://www.cobaltss.net/forums/2-0l...broken-263184/
Daniel
Daniel
I know this is an old post but I sell the hardened oil pump gears and adjustable cam gears.
I've spoken to Jeff on facebook and he made it appear that he had the exclusive on hardened oil pump gears and claims other supplier's methods of hardening are not "real" hardened oil pump gears. I tried to ask him what alloy he uses but he said it was secret. From what I could gather he has a machine shop mill the oil pump gears out of some flavor of hardened steel.
I have an old Bates hardened oil pump gear in mine. Do you know if they heat treated and used the stock oil pump gear alloy or if they used a different alloy altogether?
i did get a set of oil pump gears from jeff, but i havent put them in yet. they looks like a decent piece, but looks only go so far. ill be putting them in over winter and seeing how they hold up.
