Who is running wheel spacers??
Old Apr 11, 2012 | 09:12 PM
alerosaint's Avatar
Im thinking about running 5mm wheel spacers for a more aggressive wider stance. Any one running spacers on their TC?? Pros, cons, pics and reviews.
Old Apr 11, 2012 | 09:28 PM
peachpuff's Avatar
You sure you'll have enough thread on the studs for a 5mm spacer?
Old Apr 11, 2012 | 09:31 PM
alerosaint's Avatar
Yeah i was searching and Powell confirmed as long as it 5mm you have enough thread on the studs...ill find it
EDIT:
Link to the thread I found:
https://www.cobaltss.net/forums/newr...eply&p=6210990
here is the main part:
u folks dont understand. the 5 mm spacer remains hub centric thats the whole point. If you need 3 mm that is possible we make them for CED and can do a set for you.
its when you use a spacer more than 5 mm you have to make a big jump in width, so that there is enough metal to make it hub centric inside and outside, and you then need the GMPP much longer studs, which CED have available. ARP dont make long enough ones, and making wheel studs is not a cheap process, and the folks who make them in volume wont do it in lots less than a 1000 studs. I have made longer custom studs and have made 1.5 inch spacers; if you need longer studs, which i dont believe u do, go with the GMPP ones....
Old Apr 11, 2012 | 09:33 PM
MastaShaKe_88's Avatar
you'll be good with 5mm man, I had 7.6mm on for about 2 days an that was dangerous I'm at 3mm now an I'm good tho
Old Apr 11, 2012 | 09:37 PM
alerosaint's Avatar
How does the stance look? Did it affect your handling good or bad? I would think for the better.
Old Apr 11, 2012 | 09:39 PM
drumrush's Avatar
5mm does nothing for your stance. I personally bought extended studs and 15mm spacers, anything less wouldn't be worth it IMO
Old Apr 11, 2012 | 09:41 PM
breds2k's Avatar
Pics yet drum? Anxious to see them, i definitely want to do that soon.
Old Apr 11, 2012 | 09:42 PM
not a huge difference in tire poke or nuthin an it didn't effect handling that I can notice, they're only on the fronts right now to clear my brakes.. Ima see if I can find a before and after pic for ya...
TommyP's Avatar
AWD > FWD
spacers aren't gonna affect handling at all, will put a bit more strain on your wheel bearings though.
Old Apr 11, 2012 | 09:43 PM
09TcSedan's Avatar
i run 5mm with my winter tires... ^^ what he said
Old Apr 11, 2012 | 11:31 PM
Frogstofall's Avatar
I'm running 8mm hub centric spacers from Motorsport Tech with longer ARP studs. Top quality and zero issues.
The only problem I had was getting the hubs off bc you can't get the old studs out without doing so. I ended up taking it to a shop for that part but it worked out in the end. My hubs were fused to the knuckles just about.
Old Apr 12, 2012 | 12:35 AM
sjc0013's Avatar
Window Licker
Kinda my thoughts, its only .19 inches lol
Old Apr 12, 2012 | 12:49 AM
G_Pelly's Avatar
https://www.cobaltss.net/forums/whee...pacers-259976/
here is another thread on the samething
Old Apr 12, 2012 | 03:30 AM
alerosaint's Avatar
^^thanks
you have some pics??
Old Apr 26, 2017 | 03:32 AM
gmcsierragt's Avatar
Hey Im new here, Im running 1.25", here's some pics, I am also curious if this has side effects? I have noticed a lil shake in my steering wheel, and a little more wheel spin and torque steer, doesn't rub though!
Old Dec 29, 2020 | 06:41 PM
iceteaslurpie's Avatar
I know this is an old thread but did you have to change / modify studs at all to use the 1.25" spacers or did they bolt right on? Thanks!
Old Dec 29, 2020 | 07:02 PM
no I didnt, if I went with any small spacer I would have had to though
Solaris99
28
Mar 15, 2017 01:22 PM
DANRICKARD
Oct 1, 2015 12:08 AM
goaliemo
Sep 28, 2015 01:37 PM
SlowSaturn
Sep 28, 2015 11:03 AM
