u folks dont understand. the 5 mm spacer remains hub centric thats the whole point. If you need 3 mm that is possible we make them for CED and can do a set for you.
its when you use a spacer more than 5 mm you have to make a big jump in width, so that there is enough metal to make it hub centric inside and outside, and you then need the GMPP much longer studs, which CED have available. ARP dont make long enough ones, and making wheel studs is not a cheap process, and the folks who make them in volume wont do it in lots less than a 1000 studs. I have made longer custom studs and have made 1.5 inch spacers; if you need longer studs, which i dont believe u do, go with the GMPP ones....
not a huge difference in tire poke or nuthin an it didn't effect handling that I can notice, they're only on the fronts right now to clear my brakes.. Ima see if I can find a before and after pic for ya...
I'm running 8mm hub centric spacers from Motorsport Tech with longer ARP studs. Top quality and zero issues.
The only problem I had was getting the hubs off bc you can't get the old studs out without doing so. I ended up taking it to a shop for that part but it worked out in the end. My hubs were fused to the knuckles just about.
Hey Im new here, Im running 1.25", here's some pics, I am also curious if this has side effects? I have noticed a lil shake in my steering wheel, and a little more wheel spin and torque steer, doesn't rub though!
Reason: added info
I know this is an old thread but did you have to change / modify studs at all to use the 1.25" spacers or did they bolt right on? Thanks!
