zzp charge pipe installed
Since many people wish to run a remote mounted BOV venting to atmosphere on our upgraded turbo kit, we went ahead and manufactured an aluminum lower charge tube with a MAF pad built in. This will avoid the rich condition/stumbling associated with a draw through MAF/VTA combination.
You can use it on the stock turbo. It would just require a block-off plate for the factory bypass valve.
