08 Lnf revs drops
Old Jun 25, 2015 | 03:13 PM
Jay P.'s Avatar
08 Lnf revs drops
Last night I expierienced the rpms drop more than normal to like 300 rpms car has to be in neutral for it to do that, also once this happens the voltage of the whole car drops from like 14.4 normal to 12.2 than picks up again, If someone has any idea of what it could be let me know thanks in advanced
Old Jun 25, 2015 | 03:22 PM
Most likely a vacuum/boost leak. I'm assuming you mean they drop to 300rpm when you push the clutch in and coasting or on the brake.
Old Jun 25, 2015 | 03:24 PM
Jay P.'s Avatar
I will check for any loose clamps on pipes then, have you had this problem or similar before? I have no cel
Old Jun 25, 2015 | 03:40 PM
exninja's Avatar
Make sure your grounds are nice and snug too.
Old Jun 25, 2015 | 03:54 PM
Jay P.'s Avatar
Which grounds should I worry for?
Old Jun 25, 2015 | 04:29 PM
exninja's Avatar
There's a cable from the starter to a bellhousing bolt, and from the fuse box (IIRC) to a stud underneath the driver's side headlight. My car would drop voltage, sometimes take a while to start, less often start in power reduced mode, and the boost/vac gauge would read very low during idle. Turned out I didn't tighten the ground on the bellhousing bolt well enough. Problems cleared right up.
I figured it out when I was reading a voltage difference between the engine and the chassis. If it is grounded properly there wouldn't be a difference. My issues were also somewhat intermittent.
Old Jun 25, 2015 | 04:33 PM
umrdyldo's Avatar
I have to ask.
Was your AC on?
Old Jun 25, 2015 | 05:31 PM
Jay P.'s Avatar
A/c was off I drove it right now with the a/c on and it drives normalish lol,
Old Jul 2, 2015 | 10:37 PM
nRRe's Avatar
my car will do this while driving, in gear..cruising down the road.
every light dims some
car loses a little bit of power, like it dips 2-3mph
it's very sporadic and happens under any and all conditions of weather or speeds. also does it at stop lights sitting idle in neutral with or without the brake on.
Old Jul 2, 2015 | 11:15 PM
footballplaya3k's Avatar
08 Lnf revs drops
I've had this problem on both of my motors, I assume it's just how it is.
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
Oct 13, 2015 09:32 PM
patooyee
Oct 1, 2015 01:07 PM
DocSvensk
Sep 27, 2015 02:24 PM
