08 lnf what is the easiest way to replace clutch?
I have been having problems with clutch slipping and now i have got the opportunity to replace it, I will be replacing it with southbend stg4+ from zzp
But before I do so, was wondering if I can get any advise on easier ways to do the swap? What others have had problems with and anything that will be useful for me to know?
I will be using a lift to do so
All help is appreciated
Good luck and im in for info as well, looking to replace my clutch now that i have access to a lift and im at 80k ( dont need it yet but just want to get it out of the way now)
Well i was planning on going for a zfr but plans have changed for now. If anything maybe ill get the KO4+ but im sure a stock clutch with handle it. If anything ill put a stage one but thats about it lol
Hey blue i was looking at alldata do you have to remove the fuse box? Seemed liek that but only glanced at the steps for removal of tranny
Can do it in like 6 hours now.
First time about 12 moving slow. It was also the very first thing I did on my LSJ and I know nothing about the platform.
I had help from a member I met here. Now we've done it so many times that together we can bust one out in no time if we don't dick around and nothing gives us trouble. Hell, we just dropped the motor out of his with nothing except hand tools and a couple rachet straps. Right onto the ground lol.
I've been meaning to do the write up, I just haven't had time.
It's really not that hard.
Support the motor from top.
Pull out fuse box and bracket.
Pull wheels, ball joint pins, brakes, axles, motor mounts, steering shaft.
Undo any clip attached to the trans.
Drop the cradle.
Undo top trans mount and bell housing bolts.
It falls right out.
Drop the cradle.
It falls right out.
It's not terribly difficult, just lots of little **** to remove and put back together. I've done more clutch jobs on these cars than I care to keep track of at this point and they're still by far my least favorite trans to drop. There's just not a whole lot of short cuts you can take in doing the job to make it quicker. It's actually far easier dropping the 350+lb Allison in a duramax than a stupid little cobalt trans. lol
I think the same thing is posted on this site somewhere, but this is a pretty good write-up: 2.0 liter LNF - Clutch install (go to the pdf attachment).
I would strongly recommend having all 3 on hand. 8 out of 10 times, especially if the tob have ever been replaced, there is at least 1 bolt that I have had to weld a T30 torx bit onto in order to get it out. People LOVE to over torque those things.
Def. not an impact wrench, but i heard a driver might work. I had to weld all three to get them out. All the force I could put into it didn't help. Mine had a ton of loctite from the factory. Replaced them with some hex key bolts and the proper amount of torque.
And i mean the manual ones, not powered. Like I said, i only heard it.
