09 cobalt ss wont start
Old Mar 5, 2012 | 06:51 PM
Isamu's Avatar
Came outside this morning and the battery is completely dead. I try and jump it and still wont start, everything cuts on but it just clicks. Had it connected for a good 10 minutes, any thoughts?
Old Mar 5, 2012 | 06:57 PM
Kbbalt's Avatar
You Jumped it with another car? and On? or you just connected it to another car? You arent very clear
tomj77's Avatar
jump it with another car or a charger with jump setting
Old Mar 5, 2012 | 06:59 PM
Isamu's Avatar
Sorry, yea I jumped it with another car that was on
Old Mar 5, 2012 | 07:05 PM
tomj77's Avatar
u sure the cables were connected good, i know from expirience that sometimes even if there on, they arnt contacting good enough to get charge or full charge
Old Mar 5, 2012 | 07:13 PM
Isamu's Avatar
Im pretty sure it was all the electronics were on and the contacts were sparking when I moved them around
Old Mar 5, 2012 | 07:16 PM
tomj77's Avatar
hmmm. thats odd. sounds like its not charging up like it should. try a diff battery
Old Mar 5, 2012 | 07:21 PM
LS6Rally's Avatar
have you touched your positive post on your fuse box recently? i know it seemed that mine backed off about 2 weeks after installing my retros and that caused the issue. all the elec. would work until i turned the key to start, then they would cut out
Old Mar 5, 2012 | 07:58 PM
Isamu's Avatar
Not before jumping it today
Old Mar 5, 2012 | 08:26 PM
Isamu's Avatar
If it was just the battery wouldnt it still start while it was hooked up to the other car?
Old Mar 5, 2012 | 08:29 PM
07LSJ's Avatar
Hmm that's odd. Check the fuses...
Old Mar 5, 2012 | 08:31 PM
guitarenvy's Avatar
if its "clicks" rapidly when cranking, the starter isnt engaging all the way, meaning not enough amps are getting there.
try boosting it again, and move the cables around more to get better contact
Old Mar 5, 2012 | 08:39 PM
kikal8's Avatar
make sure u have a good ground. no paint, bare metal bolt. it can only be a couple things. it obviously isnt ur starter cause starter clicks. does the clicking slow down at all? as u try to start it? and maybe trying connecting another car and revving the engine of the running car while connected to try and give a charge for a good minute or so. then try. if still nothing.. then could be a wire problem. but wat happens when u try to start without being jumped? and wat changed when u try while being jumped.
Old Mar 5, 2012 | 08:59 PM
Isamu's Avatar
No the clicking does not slow done at all and I could try another car. When i try and start without being jumped nothing comes on and when I try to start it while being jumped everything comes on but just clicks. Im getting sparks on contact so i thought i had a good connection but i will try it again
Old Mar 5, 2012 | 09:20 PM
SSlobalt's Avatar
Go buy a new battery, put it in the car, start it, drive away.
Old Mar 6, 2012 | 12:59 AM
kikal8's Avatar
ya it sounds like the battery is SO dead that it cant even hold a charge. how long have u had that battery in the car? they usually last 5 to 6 years
Old Mar 6, 2012 | 09:07 AM
Isamu's Avatar
I got the car used about six months ago had 43k on it. The previous owner had a system on it could be related to that. And it was the battery thanks however now the radio does not power on and the tpm is blank do both of these have fuses that could have blown?
Old Mar 6, 2012 | 09:22 AM
tomj77's Avatar
Check the manual. If u don't have one, passenger side at the front of the center consol is the fuse box
Old Mar 6, 2012 | 09:52 AM
Isamu's Avatar
Alright, and also my keyless entry isnt working do you know what that we be under in the diagram?
Old Mar 6, 2012 | 10:24 AM
CudaJoe's Avatar
make sure you connect the negative to the frame of the car... I really hate watching people jump cars by connecting battery to battery....
Wait 5-10 minutes of charging. Then try to start it WHILE still connected to the running car. Once started drive to the local Pepboys or Autozone and buy a new battery. then swap it out right there and get your $20 trade in back.
Old Mar 7, 2012 | 09:55 PM
Isamu's Avatar
Yea the frame was the only place i was getting a good ground but it was just the battery thank god thanks for all the help
Old Mar 7, 2012 | 09:57 PM
advise's Avatar
$5 trade in you mean
Old Mar 7, 2012 | 09:58 PM
xbobbitox's Avatar
They take jumps better from the trunk battery, not the post under the hood. Reason I know, I jump like 50 cabalts a week at work lol
Old Mar 7, 2012 | 10:25 PM
David6312008's Avatar
True this^^^^
Regular people are like it cant be the battery because it doesnt have one
Old Mar 7, 2012 | 11:37 PM
SSlobalt's Avatar
Did you get everything working?
Decepticon06ss/sc
Oct 16, 2015 09:24 PM
ashalle2
Sep 16, 2015 10:36 PM
Wind
Sep 11, 2015 06:57 PM
Sabon_SS
Sep 7, 2015 12:39 PM
