09 SS Coolant Hose
Old May 22, 2014 | 01:19 PM
Kurisutofa's Avatar
09 SS Coolant Hose
My ZZP Intake crimped the coolant hose it's next to and when I moved it I noticed it damaged the hose and I'm now leaking Coolant. Anybody have any idea the part number I can get that hose from?
Old May 24, 2014 | 07:53 PM
reifercheefer's Avatar
Same thing happened to me. If its the rubber section and the metal is good, get a piece of hose from napa and cutthe chewed hose away . Make new hose a bit longer and dont smush it.
also coolant return is all one piece like 140 dollars called turbo coolant return line sonnnnnnnn.
Old Oct 7, 2014 | 09:03 AM
NickD's Avatar
I know this is an old post, but does anyone know what the diameter of this hose is? I have the exact same issue as Kurisutofa, except with my Hahn piping. It was the hose clamp head rubbing against it.
Old Oct 7, 2014 | 11:41 AM
tomj77's Avatar
Take off the hose and check, I forgot what it was, I had to get new hose when I installed my Zfr cause the rubber was baked onto the metal part and when I tried to pull it off the hose split , like as in if u were skinning an animal. Half the thickness stayed on the other half came off . Was weird.
Old Oct 7, 2014 | 11:45 AM
NickD's Avatar
I would do that but as of now I need to drive my car to the autostore. I don't want to pull it off while under pressure. Also, one of the hose is a taditional hose clamp, the other is the type you have to cut off. Which means I'll be doing the work in the parking lot; I'd rather not.
Old Oct 7, 2014 | 12:45 PM
tomj77's Avatar
U can tank it off by the engine, it's just a clamp only need pliers . Would take 2 minutes. Or simply do it at home , hook it back up and go buy ur hose, ur making to much of it when it's really simply .
Old Oct 7, 2014 | 12:47 PM
NickD's Avatar
I agree, it's easy to get off in a parking lot, no big deal. But I have to wait for the pressure in the cooling system to drop. That'll take a good 20-30 minutes before I can open the cap and release the rest of it. That's my only issue.
Old Oct 7, 2014 | 01:08 PM
iirc you can use a -6AN line
Old Oct 7, 2014 | 01:16 PM
tomj77's Avatar
What's a little scolding coolant all over u lol
Old Oct 7, 2014 | 01:17 PM
NickD's Avatar
-6AN is 3/8" I believe. If I was to go with a braided line, I would need to install fitting on the ends of the hard lines. Hmm... This can get pricey quick.
Old Oct 7, 2014 | 01:19 PM
NickD's Avatar
Seperating the men from the boys (or the skin from the bone)? Heh. I'm not loosing much coolant, I can make it until Thursday and I'll have my motorcycle ready to ride again. So I can pull the hose off Wednesday night. That should work. I was hoping to stop on my way home, but whatever.
Old Oct 7, 2014 | 01:38 PM
Its a low pressure system, should max out around 20psi. Hell the stock system uses band clamps, so a worm drive clamp will hold just fine, add a flare to keep it from slipping off and boom fixed.
Old Oct 7, 2014 | 01:47 PM
NickD's Avatar
Okay, I like the sound of this. You're right, it's only 20psi. Using a worm drive clamp on the braided line, will I have to worry about the braid becoming frayed at the end? Also what exactly is a flare in this context?
Old Oct 10, 2014 | 08:51 AM
NickD's Avatar
Just an update. The SS braided hoses are on backorder from where I ordered them so I tossed a single ~2' long hose on there for now. 3/8" fit perfectly.
What I did see with the old hose was interesting. The heat got so intense it seperated the two layers of the hose. The inner layer was firmly sealed to the hard line but a leak started further down where the outer layer seperated (braided nylon between the layers).
I am guessing this was a mix of the heat and the intake possibly rubbing up against it. I do know that after a 20 minute track session the heat after shutdown is too hot for me to keep my hand held ~6" over the back of the engine by the turbo. This last track weekend my spot in the paddock wasn't quite level. So I couldn't leave the engine idling to cool things down. I noticed it would start getting about 220. Once I realized this I'd leave the paddock and drive around a bit to let things cool.
Old Oct 10, 2014 | 09:06 AM
Are you tuned? and have you bleed your coolant system to make sure there are no air bubbles?
Old Oct 10, 2014 | 09:10 AM
NickD's Avatar
Yes and yes.
Old Oct 10, 2014 | 09:13 AM
Who's your tuner and how much timing are you running on your track tune?
Old Oct 10, 2014 | 09:14 AM
NickD's Avatar
I just have a fairly basic Trifecta tune, I use it for street and track.
Jan 12, 2016 12:01 AM
brandon04
Oct 21, 2015 07:04 AM
grampss
Sep 27, 2015 08:51 PM
riceburner
Sep 26, 2015 12:57 AM
OrangeCoba
Sep 25, 2015 06:06 PM
