09 ss hesistating p0114,
Old Jul 18, 2016 | 11:28 PM
mikeluis92's Avatar
any1 had this? changed MAF sensor, ?
Old Jul 19, 2016 | 08:23 AM
umrdyldo's Avatar
Try unplugging the MAF and see it runs better.
Check wiring to MAF and then probably change sensor
I see that you are searching around, I couldn't find where many people had had that code.
Old Jul 19, 2016 | 09:14 AM
mikeluis92's Avatar
thank you, I unplugged MAF sensor now the car runs fine. It is throwing P0119 when I have it unplugged. I did just have the engine rebuilt and my mechanic says a tune would fix this issue.... I talked with my tuner he told me my mechanic fucked up on something there... My cruise control isn't working neither, and fans are staying on way longer than they should.... any feedback? thanks for response
Umrdydlo
Old Jul 19, 2016 | 09:21 AM
mikeluis92's Avatar
also the car is showing coolant ---- I clear the code it shows it at 60.... then goes to 0
Old Jul 19, 2016 | 10:03 AM
umrdyldo's Avatar
Check the wiring to the engine coolant temperature sensor. Also could be thermostat I think. Not sure about that.
Otherwise you may still be looking at a wiring issue. Wiring to the ECT or MAF could be damaged.
Old Jul 19, 2016 | 10:05 AM
Could be the thermostat
Old Jul 19, 2016 | 03:16 PM
mikeluis92's Avatar
I put new thermostat, left the car wit tech today to check it, they also swapped coolant egt sensor? also on my RPD when I clear the codes the coolant reading is going from 165 135 120 70 60 54 then ----, fans are staying on a lil longer than usual, I have to unplug my MAF for car to be driveable if not its hesistation off. I put new fuel... Hes checking wiring now but engine is running smooth at idle and driving aswell I just cant go into boost right now.
Old Jul 19, 2016 | 04:10 PM
YelloEye's Avatar
Fans are staying on because the coolant temperature sensor isn't reading correctly. Beats them not running at all and the car coking all your oil and then spinning a rod bearing because it's overheating.
This has something to do with either your coolant temperature sensor not being plugged in, needing replaced, or there's an issue with your wiring.
Cruise control not working could be your 3rd brake light is out.
Old Jul 19, 2016 | 04:41 PM
umrdyldo's Avatar
Make sure you are using only GM parts. Especially EGT, MAF and thermostat.
Cruise control is either brake light out, or brake light switch is bad.
Old Jul 20, 2016 | 02:32 AM
mikeluis92's Avatar
Intake got disconnected, cars reading MAF now. lets see how it runs picking it up tomrow thank you for the feedback
Old Jul 20, 2016 | 02:33 AM
mikeluis92's Avatar
is it normal now that I rebuilt it for it to smoke a little from exhaust when I cracked cyl 3 it smoked like hell now I rebuilt it has some smoke coming from exhaust... tech says it will be about 2 months of that for it to settle the piston rings that true?
Old Jul 20, 2016 | 08:00 AM
umrdyldo's Avatar
No i don't think so. If they are moly rings they could take 500 miles maybe, but I think most rings seated very soon.
Old Jul 20, 2016 | 08:37 AM
If you follow most piston/ring manufactures recommendations they should seat fairly quick. You still may have some smoking, it's tough to saw whats normal and what indicates a problem from the internet tho
Old Jul 20, 2016 | 01:14 PM
mikeluis92's Avatar
no more smoking and also car has no codes p0013 camshaft position sensor? cleared the code it went away. has nt came back, idle fine, should I retune?? I put LDK pistons and pretty much stock build, cars 100 now
Old Jul 20, 2016 | 01:23 PM
mikeluis92's Avatar
how long to break in engine? and do I leave same tune on it?
Old Jul 20, 2016 | 01:25 PM
mikeluis92's Avatar
there so sensitive a loose intake no cruise control, mph, car runs like crap. but all fixed now. :]]]
Old Jul 20, 2016 | 02:21 PM
umrdyldo's Avatar
500 miles is a decent break in. Then change the oil.
I"d leave stock or GMS1 tune on it. Don't go full throttle a lot.
Old Jul 21, 2016 | 02:09 AM
mikeluis92's Avatar
I'm hp tuned just driving on this tune I'll do. That thanks for advice
Doug's Cobalt SS SC
Jul 9, 2019 11:33 AM
onlyjosh
Nov 2, 2016 06:55 PM
*TRIX*
Jul 20, 2016 04:04 PM
timichaud
Tuning
Jul 6, 2016 08:39 PM
Rdkdiz
May 4, 2016 07:02 PM
