1st and 2d Gear "Whine?"
Old Jan 9, 2012 | 09:24 PM
nobody2u's Avatar
Hey all, wondering if I might have a potential problem. I'm not sure if everyone gets this or what- but I don't think it was there when I first got the car... I'm getting a sort of whining noise from the engine, it isn't too loud and not sure if it can be heard outside of the cabin or not. It seems to happen when accelerating slowly in first and second gear. Seems to go quiet after that. Wondering if anybody else has experienced it. Could it be my belt needs to be sprayed? The whine seems to get higher pitched as the rpms go up, so maybe it is the belt?
Do I have a potential problem? Is it possible that it's related to the cold weather of winter now?
Thanks
Old Jan 9, 2012 | 09:50 PM
09CobaltSS1's Avatar
The trans tends to whine a bit particularly when cold. As long as you aren't hearing a whine when you're in boost then there should be no cause for concern
Old Jan 9, 2012 | 09:54 PM
iLikeBoost's Avatar
This. Also, our car's drivetrain is a bit on the noisy side to begin with. You should never need to spray your belt.
Old Jan 9, 2012 | 11:16 PM
tomj77's Avatar
Thanks
if it sounds like a rc car, thats normal.
Old Jan 10, 2012 | 09:57 AM
nobody2u's Avatar
Perfect thanks guys.
Old Jan 10, 2012 | 01:28 PM
Shanedude's Avatar
Try downshifting into 1st when coming to a stop it will whine a bunch. Would like to hear it from the outside.
Old Jan 10, 2012 | 03:38 PM
Nfamous60's Avatar
does it happn when you push in the clutch pedal mines did it after a clutch swap, found out it was a throw out bearing.
Old Jan 10, 2012 | 04:02 PM
nobody2u's Avatar
Umm.. I don't think it does when the clutch is in. Can't remember though.
RyRidesMotox's Avatar
Wait, Wait, Wait... who told you it was ever ok so put ANYTHING on an engines accessory belt or timing belt? That is the only problem I see in this post. Your trans is fine.
Old Jan 10, 2012 | 04:11 PM
sponge14's Avatar
Probably talking about the old school belt dressing to stop squealing belts.
Old Jan 10, 2012 | 04:12 PM
RoadconeTuning's Avatar
mine whines and i took it to the dealer a few days ago for that among other things... basically i've been told it was normal. they've recently torn down another local guys trans apart and replaced the bearings when he had actual issues so i'm pretty sure its just normal FWD transmission taking power and flexing/wearing... they were aware of them pushing the input shaft out so i'm just going to wait for it to get worse.
Old Jan 10, 2012 | 04:42 PM
Shanedude's Avatar
Could it be the way the 1 and 2 gears are shaped? I remember seeing a video on jbody that had some kind of british race cars that made the same whine noise as the ss/tc's, just ours is a lot more subtle then the video's.
Old Jan 10, 2012 | 04:53 PM
i think u mean the same sort of whine but quieter like when ur in reverse? i dont think its a problem
nobody2u's Avatar
Yes! That sort of sound.
Old Jan 10, 2012 | 04:56 PM
DoMiStIc_RuSh_06's Avatar
Its normal, mine car does it to. Even more noticable with the cold weather.
Old Jan 10, 2012 | 04:58 PM
yea i never noticed it until it got cold out, then i thought yea its just a manual tranny thing no big deal. glad i had it clarified anyway
Old Jan 10, 2012 | 06:00 PM
nobody2u's Avatar
Alright sounds good guys. I just got my injector problem solved and was thinking I had a new problem like "here we go again." Good to know that I'll be able to drive my car issue free for the first time since I got it in May.
Old Jan 10, 2012 | 07:18 PM
FRQ FLYR's Avatar
Like everybody says-"normal" unless you hear it at cruising speed. I had bearings and a gear replaced (took over a month). Still whines when cold even after lube change.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
biniecki
Oct 25, 2015 02:23 PM
DocSvensk
Sep 27, 2015 02:24 PM
ashalle2
Sep 16, 2015 10:36 PM
