Adjusting the waste gate for more boost?
Old Oct 23, 2011 | 09:29 AM
JHAG's Avatar
Does anyone know or has anyone adjusted the threaded rod on the waste gate coming off the turbo? By adjusting that rod will that increase or decrease my boost? Like on the Buick Grand National by adjusting this threaded rod you can change your boost 1 turn equals 1 pound.
Old Oct 23, 2011 | 09:54 AM
BLAZIN07SS's Avatar
I'm too JDM for you
boost is controlled through the PCM. get a tune to change boost levels. don't mess with the wastegate rod
Old Oct 23, 2011 | 12:35 PM
Malaclypse's Avatar
^What he said.
If you start messing with the wastegate adjustment it'll cause you all sorts of problems. Just get a tune.
Old Oct 24, 2011 | 07:11 PM
tomj77's Avatar
besides if u manually up the boost the car will learn, adjust, and ull still get stock power. u have to tune it.
Old Oct 25, 2011 | 09:57 AM
JHAG's Avatar
I have the GM turbo upgrade kit already installed and that puts me at 21psi I was just wondering if there was a way to say have a soild 23psi?
Old Oct 25, 2011 | 10:48 AM
JHAG's Avatar
And let me ask this with already having the GM turbo upgrade kit would i benefit from a tune hp or trifecta and is it possible to do this tune and keep that upgrade? And what would the benefits be?
Old Oct 25, 2011 | 10:52 AM
BlackSS185's Avatar
yes night and day difference in gms1 and hpt..................... hpt is the way to go
Old Oct 25, 2011 | 10:54 AM
JHAG's Avatar
can i get the hp tune with leaving the gms1 kit on there?
Old Oct 25, 2011 | 10:55 AM
jphugel11's Avatar
Go get HPTuned and you'll know the benefits
I got HPTuned in July and was GMS1 with a catless downpipe and airbox mod and thought my car was fast then (best 1/4 pass was a 13.5) but once I got HPTuned I realized how deprived I was. This car needs a tune. Just do it.
(my $.02)
Old Oct 25, 2011 | 10:56 AM
emiller's Avatar
Yes. It just changes the boost parameters. No mechanical changes.
Old Oct 25, 2011 | 10:57 AM
BlackSS185's Avatar
yes, the upgraded map sensors are a benefit, the actual gms1 tune wont be there but it is still compatible with hpt.
Old Oct 25, 2011 | 11:02 AM
JHAG's Avatar
would you guys buy the hp tune and do it yourself or find someone around to do the tune?
Old Oct 25, 2011 | 11:11 AM
BlackSS185's Avatar
if i was you i wouldn't, if you have never done it before now might not be the time to start, you can certainly buy HPT and byt or any other reputable tunner can help you via email but you are close enough to just drive to his shop it might be a 3hr drive but it will be worth it and cheaper then buying HPT..... i drive 2.5 to have him tune me......IDK if byt will be doing one but you can wait and see if he will be doing any more dyno days in Pottstown PA. that may also be closer
Old Oct 25, 2011 | 02:35 PM
JHAG's Avatar
I live in Westminster MD does anyone know someone that they would recommended that can do this tune?
Old Jan 10, 2012 | 08:26 PM
vahdyx's Avatar
Question, could this have been adjusted when I got my K04+? if so how do I make it back to normal?
Old Jan 10, 2012 | 09:19 PM
80vetteL82's Avatar
For what its worth I had GMS1 and I just tuned over it with Trifecta. Now, with cruise control off Im in trifecta running 22-23psi, cruise control on is back to GMS1 making about 20psi. Its night and day, fast as hell now! I also have a Dejon SRI and TurboXS catless DP.
Old Jan 10, 2012 | 09:26 PM
FasterIsBetter's Avatar
That wouldn't cause a no boost issue since you were making 20psi unless your wastegate is stuck open.
Old Jan 10, 2012 | 11:15 PM
vahdyx's Avatar
I see, but I think it is stuck open. I can't make boost, my max boost is 0 psi at the moment
turbochargedss2012
Sep 20, 2023 12:17 PM
Jan 12, 2016 12:01 AM
justinchinn
Oct 2, 2015 12:18 PM
