1st gear boost on GMS1
Old Feb 26, 2010 | 02:59 PM
cresintern's Avatar
I heard some say that 1st gear is limited to around 8lbs with gms1, but with mine I can achieve around 10-12 lbs with the gms1... btw what is stock setup concerning boost limit in 1st??
Old Feb 26, 2010 | 03:11 PM
CudaJoe's Avatar
thats wierd. I think the GMS1 is limited to 18 psi in first and 22-23 in the remaining gears....
Old Feb 26, 2010 | 03:24 PM
Terminator2's Avatar
It is mostly load related. 1st gear is a light load on the engine so it will not produce as much boost pressure as the other gears even if it is commaded to.
Old Feb 26, 2010 | 03:37 PM
09BlueBaltSS's Avatar
I dont know about GMS1 settings. Stock for me seemed like I was making like 12-15psi and then theres the throttle limit which is something like 66% throttle in first gear. Damn torque management
Old Feb 26, 2010 | 05:47 PM
C.F.G.S08's Avatar
i have only gotten about 13 lbs trying to see what i can get out of it when i just had my gms1 tune...
Old Feb 26, 2010 | 05:57 PM
oowah's Avatar
Yeah, I make something like 9-12psi (well, for me it's 60-80kPa) in first with stock tune. I would think the amount of boost would vary quite a bit depending on enviromental conditions and engine load, so its likely difficult to compare without being in similar conditions. *shrug*
turbochargedss2012
Sep 20, 2023 12:17 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
biniecki
Oct 25, 2015 02:23 PM
maliki778
Oct 1, 2015 07:39 PM
