2.1L High Compression Build
Old Dec 17, 2018 | 01:49 PM
KMO43's Avatar
So youre going to use a gen2 LE5 block as the basis for this build? Whats the end power goal?
Yes we are using an LE5 block. I don't really know his end goal. He basically wants a better spool and more TQ. He made 440hp last dyno.
Old Dec 17, 2018 | 02:02 PM
I wish you more luck than I had using those blocks.
Old Dec 17, 2018 | 02:04 PM
Slowbalt is the the last type of engine that you blew up?
Old Dec 17, 2018 | 02:19 PM
KMO43's Avatar
Thanks me too!
Ya he has cracked an LE5 block or 2. We are running a smaller turbo and stock cams. Thus is what he wanted for a better track car. The main track he goes to is not a big HP track he's just looking to have a lower powerband to help leaving the corners. We usually turn it down for track days anyhow.
Old Dec 17, 2018 | 02:40 PM
Ive split the sleeves on 2 le5 blocks. Maybe running a higher pressure coolant cap would help
Old Dec 17, 2018 | 02:44 PM
KMO43's Avatar
There ya go! More PSIs for the other side of the cyl to hold in all the boost PSIs!!
Old Jan 8, 2019 | 11:16 AM
KMO43's Avatar
I was able to do a bit more work on the build over the weekend. She was pretty clean compared to the LE5. I also started porting the head. I'm going big on the exhaust to get the air out but will be keeping the intake side mild since we will be running stock cams.
Old Jan 11, 2019 | 01:54 PM
KMO43's Avatar
We will be back at the build again this weekend. We are doing some very interesting block mods that I will be sharing!
Old Jan 11, 2019 | 04:24 PM
Nice in for more info
Old Jan 11, 2019 | 10:02 PM
63 Nova SS's Avatar
Nice!
Old Jan 17, 2019 | 08:43 PM
  #36
96S1's Avatar
Subscribing to this new guy's thread . . .
The build up is nice and all but check out that badass street sigh tho -
2010CobaltLTfan
May 2, 2014 02:30 PM
BartSS
Feb 28, 2012 12:01 PM
1BadBlueSS
Mar 18, 2010 05:42 PM
