2 and 3 steps colder plugs
LTR7IX-11...2 step colder
check this out
http://www.modernperformance.com/081...c-473_594.html
nvm...those are iridium. just saw that in your post...i fail
check this out
in my expirience iridiums tend to run hotter, and hold more heat in (negating the some of the benefits of a cold plug) because iridiums usually have a tip with a smaller surface area because iridium is stronger making it not neccassary. further the whole benefit of iridium's is that it last longer before the tip breaks down, but on a real cold plug it will foul out long before the tip breaks down. so it's kind of pointless. also i have found that they tend to be brittle and can break easier under lighter detonation. I'll use it if i have to right now my best choice is the LTR7IX
Iridium has a melting point of 4471 degrees.. thats typically not associated with an element that witholds heat. It is a super hard, and yes super-brittle element, but that doesnt mean weak. Are you attempting to angle or align your plugs to squeeze another hp out of em or something? If not, im not sure why you have this notion about iridium being bad or fouling faster, but to each their own. The smaller "tip" also makes the spark more precise with less surface area exposed, not that in this kind of application thats a nescessity or even a measurable benefit.
I have never heard of a 3 step colder plug only 2 step... And I've always wondered this but what is the technical reason to run like a 2 step colder plug in the lnf? Would it help at all close to stock? Not meaning to thread jack or anything lol. Also I've never had a problem with the iridiums! I like ngk!
just from past expieriences with LS motors both N/A, nitrous, and forced induction. I have seen on at least a dozen occasions cars with iridium be more prone to kr and said kr get fixed by switching to standard plugs of the same heat range. It's not weak at all but from what I seen its more prone to snapping off a ground strap at certain stress points due to brittleness. The whole purpose of irridium is so it lasts a large amount of miles which is great but on a very cold racing style plug it will foul out long before the irridium breaks down. just like any very cold plug will foul out quick.
Im looking for 2 step right now since I have the ZZP kit. 3
I guess I would still value the iridums improved arc over traditional plugs. but ive never owned a motor that would use such a thing lol.
Ive been running the 3787s which are one step colder for like 4 months now and my car HATES them now. its misfiring like a bitch up top and im gettin sum knock too. Goin back to stock next week. Car liked those
You are probably going to have to change them a lot more often then the IR plugs. Also. this car is prone to misfires if plug gap and heat range are not perfect.
I run LTR6IX plugs, which I believe is ONE step colder and I gap them at .032, this is absolutely the sweet spot for a semi-agressive tune. And/or if you are running a low flow rate water/meth injection. I use the same plug daily driving and on the road course, on a MUCH more aggressive tune, both run with zero knock, the plug itself looks good and seems to be the correct range every time I check it. The ONLY complaint is I lost a slight bit of MPG changing to this plug but not enough to worry about it.
yeah I change them every 6 months anyway. Do any of you guys know of any 2 step colder plugs other than LTR7IX
None that I ever found to fit ala NGK, sorry. The 6510's (LTR7IX) you list are pre gapped to .044 so it's a challenge to gap them down to .032 and NGK only recommends gapping down .008 from mfg due to alignment issues. Currently running the 6509's (LTR6IX) but like the 3787's better IMO and they come gapped to a tight .032. (Also a HR 6)
Minimal misfires logged with any of the three listed.
sorry to thread jack didnt wanna start a whole new thread...wat plug should i run and both heat range and gap..mods are in my sig im currently boosting 14 psi and getting misfire
stock plug part number
Replacement oe plugs it is for me but what is part number for them? I may save a few bucks goin outside of dealer. Someone mentioned u can't gap these iridium plugs??!! They come factory at 035. I'm sure they can be gapped to 032 though
dont b lazy
Just look up the part number for the plugs. I think they are ngk but are made by ac delco. Or just go to dealer and get em. How much u gonna save ordering them online or goin to.a parts store? And don't know if u can gap iridiums? If ur only gapping from 035 to 032 I don't think its a problem but be careful because iridium is very hard and can break. U have a black sedan don't u? I saw u the other day spinning ur wheels at like 50mph, learn to drive bro.
wasnt i
P.S i know how to drive my car
agentirons
Oct 16, 2015 02:11 AM
