2.4 DI in the works?
Old Nov 8, 2008 | 04:10 PM
pjk91's Avatar
I did some searching and found that there is a 2.4 DI (n/a) in the works for the equinox. Predictions run between 200-210hp. Imagine boosting one of those suckers.
Old Nov 8, 2008 | 04:13 PM
joeworkstoohard's Avatar
moreover, it would probably not be a bad option to swap out the 2.0 from the TC to 2.4
Old Nov 8, 2008 | 04:20 PM
steddy2112's Avatar
There is 2.4 LNFs that already exist.
Old Nov 8, 2008 | 04:22 PM
pjk91's Avatar
What car comes with a 2.4 DI ?
Old Nov 8, 2008 | 04:25 PM
steddy2112's Avatar
Nothing comes with it per se.
WHy am I having troubles finding it...they have bored the LNF to a 2.4 lettme see if I can find it
factory?
Old Nov 8, 2008 | 04:28 PM
steddy2112's Avatar
http://www.sportcompactcarweb.com/fe...car/index.html
Old Nov 8, 2008 | 04:33 PM
08BlackSS/TC's Avatar
nice
Old Nov 8, 2008 | 04:39 PM
steddy2112's Avatar
Yeah that Solstice is old news.
Now HKS goodies on an LNF make me drool.
ENGINE
*Engine code Ecotec-LNF
*Engine Displacement/Type/Valvetrain: 2364cc, in-line four, aluminum block and head, DOHC, four valves per cylinder, variable valve timing, turbocharged and intercooled
*Internal Modifications: Thick-wall iron sleeves bored to 89mm, billet steel crank stroked to 95mm, custom pistons, rods and cams, CNC head porting, hydraulic lash adjustment eliminated, compression ratio raised to 13.7:1
*Extrnal Modifications: Custom barrel valve intake manifold, HKS tubular exhaust manifold, GT2835 ball-bearing turbo, GT2 wastegate, blow-off valve and intercooler
Old Nov 8, 2008 | 04:42 PM
pjk91's Avatar
oh yeah, i was talking factory 2.4DI. That is a badass car though. 13.7:1 plus boost? Damn.
All I have to say is, just look at it....
Old Nov 8, 2008 | 09:27 PM
1WhiteSSTC's Avatar
i want that solstice!!!!!!! You gotta hand it to GM for tapping into the Drift world
mmmmmmmmmm
*Drivetrain Modifications: Six-speed Tremec (Chevy SSR), Exedy twin-disc clutch and custom flywheel
Old Nov 9, 2008 | 01:34 AM
krispy's Avatar
bored and stroked don't count lol
All engines will be DI in a few years here, so a 2.4 DI engine wouldn't be surprising.
Old Nov 9, 2008 | 07:09 AM
Baldturbofreak's Avatar
IM 99% sure that care is port fuel injected and runs E85
THe extra 400 cc's comes from stroke..
Old Nov 9, 2008 | 09:48 AM
madlion's Avatar
instead of swapping the 2.0 for the 2.4.. take that money and swap the 2.0s internals and turbo. 2.0s can make plenty of power
Old Nov 9, 2008 | 10:00 AM
gatekeeper's Avatar
Originally Posted by Baldturbofreak
IM 99% sure that care is port fuel injected and runs E85.
E85 is pictured on the valve cover. It's would have to run something like straight 110+ octane leaded, or E85 to run those compression ratios....and boost. 800rwhp, detuned to ~500 must be crazy though!!!
RaginChopsuey
Oct 27, 2015 01:27 PM
dennis69
Oct 20, 2015 04:49 PM
patooyee
Oct 15, 2015 05:11 PM
SSLOW06
Oct 1, 2015 07:21 PM
