2010 Cobalt SS turbo boost/intercooler issue
Old Nov 10, 2014 | 07:09 PM
Exracer2's Avatar
Hit a curb yesterday and broke the clip on the left side of the intercooler. Visually there is no other damage. I had it on a lift today and the hoses coming to and from the intercooler are on and have not popped off. I have yet to remove the intercooler to check for any other damage. 50KM after the hit I got a mass airflow sensor code. Once I cleared the code it reappeared a half hour later.
Boost is low based on the stock display by the windshield.
I keep reading about intercooler pumps etc. I have searched but I am getting more confused than anything else. If I need to replace the intercooler with aftermarket is there anything I need to know? Any insight is appreciated.
Old Nov 10, 2014 | 08:13 PM
SR Tech's Avatar
Sounds like you cracked the IC
I have the ZZP IC and have no complaints. Would recommend it
Old Nov 10, 2014 | 08:31 PM
kzak104's Avatar
cracked intercooler
Old Nov 10, 2014 | 11:24 PM
tomj77's Avatar
turbo cobalt has no intercooler pump, that's for lsj which has liquid cooled intercooler. u ripped off the moister collector on the intercooler and in the process caused a boost leak, ur intercooler is done. goto zzp and get their intercooler. problem solved
Old Nov 11, 2014 | 01:56 PM
Exracer2's Avatar
I apologize for my ignorance. This is my wifes grocery getter and 100% stock. I assumed that aftermarket would be cheaper but the ZZP website has a new intercooler at $749.
I don’t need more performance just looking for an economical option and assumed aftermarket would be cheaper than stock.
Old Nov 11, 2014 | 01:57 PM
blueLNFftw's Avatar
Its not.
Old Nov 11, 2014 | 03:48 PM
tomj77's Avatar
no ur looking at the intercooler package, with the charge pipe, the intercooler itself is 349
ZZPerformance - LNF Front Mount Intercooler #ZZ-LNFFMIC
Old Nov 11, 2014 | 03:50 PM
tomj77's Avatar
ull want to pick the smaller size one, as the normal size one hangs 1/4 under the bumper and the smaller size one does not, makes it less likely to get damaged
Old Nov 18, 2014 | 10:16 PM
Exracer2's Avatar
Busted end cap.
Replaced with a ZZP aluminum unit (smaller one). Thanks for the advice guys.
Old Nov 19, 2014 | 06:39 AM
reybalt's Avatar
oem intercooler is expensive, just buy an aftermarket.
Turbo Johnny
Feb 21, 2019 09:41 AM
allpro666
Sep 23, 2015 07:47 PM
Sean Cummings
Sep 11, 2015 09:35 PM
CobaltSS 16
Sep 6, 2015 02:04 PM
