2011 Buick Regal Turbo
Old Nov 27, 2010 | 10:32 PM
MapOfTaziFoSho's Avatar
LHU Engine, 2.0L ECOTEC DOHC 4-cylinder SIDI (Spark Ignition Direct Injection), VVT (Variable
Valve Timing) intercooled turbo and E85 capable (220 hp [164.0 kW] @ 5300 rpm, 258
lb-ft of torque [348.3 N-m] @ 2000 rpm)
So, I don't know a TON about this new engine, but I do know that the ECU is NOT a Bosch unit, and the turbo is slightly different. Other than that, I'd love to know if anyone has any thoughts on the LHU giving us more E85 options.
Old Nov 27, 2010 | 10:36 PM
blacklightmachine's Avatar
All the DI GM's use the same injectors and mech fuel pumps.
Old Nov 27, 2010 | 10:50 PM
Ch1ck3n's Avatar
If it's e85 capable, that's good news for LNF's.
09CobaltSS1's Avatar
All?? Including all of GM's high performance DI lines set to come out in 2012 I believe? In particular the Corvette engines? If that's the case then maybe they are using some sort of a multipump system with 1 per bank. ::shrugs shoulders::
All I know is the fact that so many manufacturers are converting over to DI (GM will be exclusively DI supposedly by 2012) opens the door quite a bit more for platforms such as the LNF to expand. Even though the cobalt aftermarket isn't exactly steller, the demand for DI support on the Corvettes should carry over hand and hand especially if they do use the same pumps and injectors.
Old Nov 27, 2010 | 11:14 PM
steddy2112's Avatar
Yep.
Talked to someone who went to school to learn about all the future GMs.
Old Nov 27, 2010 | 11:36 PM
Matt M's Avatar
LLT Camaro injectors are smaller then LNF injectors. Turbo Regals are set to be flex fuel in a couple months, which will most likely mean larger injectors will be used. I would expect some type of pump upgrade as well. Its pretty easy to max the current pump on E85.
Old Nov 27, 2010 | 11:48 PM
steddy2112's Avatar
Not at stock power though.
The thing that is more interesting than anything is the PCM being different, because I doubt the make MAF changes like LNF users do to compensate for the different 'stoich'
And I correct my statement: all the turbo DI fours have the same injectors.
Old Nov 28, 2010 | 12:54 AM
Matt M's Avatar
Flex fuel turbo Regals are supposed to be optimized for E85 and the ECM will change the tune for lower percentages of ethanol based on alcohol sensor readings. They are talking about some pretty significant differences in power output.
Old Nov 28, 2010 | 12:57 AM
steddy2112's Avatar
Hey I don't mind being all kinds of wrong...especially in this case
Old Nov 28, 2010 | 01:04 AM
Matt M's Avatar
What's interesting is that some of the older ECMs already have flex fuel charts in them. They just aren't enabled. I always wondered how difficult it would be to convert existing Cobalts to flex fuel the "right" way.
Old Nov 28, 2010 | 01:16 AM
steddy2112's Avatar
Well some of the LE5 ones are Flex Fuel, I thought
Old Nov 28, 2010 | 09:49 AM
Wangspeed's Avatar
I want to know if they run 110x5 wheel bolt pattern.
Old Nov 28, 2010 | 12:54 PM
Iam Broke's Avatar
Cruze is 105x5, IDK about the Regal
Old Dec 5, 2010 | 12:38 AM
jboogie's Avatar
why gm.........just why?
Old Dec 5, 2010 | 04:30 AM
RyRidesMotox's Avatar
To **** with us all...
I hope the injectors are the same... A bigger pump and new injectors would be a simple enough mod with a good tune. Maybe a new ECM too but if E85 starts being more available around here I might have to look into this.
Old Dec 5, 2010 | 04:37 AM
40rty's Avatar
GM will be using the old Delphi ECM's for the new Regal turbo. Have you looked at a cruise lately? Delphi ECM. Sucks
Old Dec 5, 2010 | 04:49 AM
I said maybe a new ecm but that is only if this one can't run the lnf on e85. I'm pretty sure someone could tune for it. Term is amazing so if this injector/pump swap is possible he will get the call... First e has to become more readily available here.
Old Dec 7, 2010 | 05:48 PM
shabodah's Avatar
GM News - United States - News
The ECM for the LHU is a huge step forward. Most importantly, it should be a good step in controlling direct injection at higher rpms much better.
If only the powertrain was in the Cruze instead of the Regal...
Supercharged06SS
Dec 11, 2022 04:47 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
patooyee
Oct 15, 2015 05:11 PM
maliki778
Oct 1, 2015 07:39 PM
