2nd gear grinding out of no where!!
Old Aug 29, 2012 | 01:43 AM
lazaro's Avatar
i went to reduce to 2nd gear and it just started grinding it got more progressive, and now it grinds when you try to engage it when the car is moving is it stopped it goes in normal, its only second gear, note i was not abusing the car when this first happened
Old Aug 29, 2012 | 06:39 AM
SSlobalt's Avatar
Probably just a cable clamp issue. I don't know the procedure on adjusting the clamps, but if you look under your cup holder and look at the plastic white clamps, make sure they're not snapped.
Old Aug 29, 2012 | 08:45 AM
JBThrasher22's Avatar
My car has just had to have the 2nd gear syncro replaced. So has a few other members that I know about. I would guess your 2nd gear syncro is going out, if it is a grind up shift or down shift at any rpms over idle. You could check your cable clamp as it could be broke or out of adjustment but I bet it is going to be your syncro.
Old Aug 29, 2012 | 08:47 AM
tomj77's Avatar
I'd say check easiest thing first, u have floor mats? If yes, if they slip under the clutch peddle it doesn't disingage properly and u'll grind, Iv had that happen. If that's not it, check cable linkage, if that's ok, probably ur tranny. Warrenty
Old Aug 29, 2012 | 09:03 AM
lazaro's Avatar
Hard to get warranty with a big turbo lol. I should be a clamp i never do 20 rolls always 40 and 60s so second gear should be good
Old Aug 29, 2012 | 09:41 AM
tomj77's Avatar
Oh didnt, well hope they don't look. Lol
Old Aug 29, 2012 | 12:10 PM
Red_SS/TC's Avatar
Pretty sure it's your 2nd gear synchro. Same exact thing happen to mine after my brother drove my car. Dealership ended up replacing my whole transmission. I don't think it could be the cable since mine has always needs adjusting out but never causes me to grind a gear.
Old Aug 29, 2012 | 12:54 PM
gone_in_10_sec's Avatar
It's your syncro's, most likely the dealership will replace it with a new one, and over look the big turbo setup.. if I was you, I would stop driving the car, until it's fixed.. grinding the teeth off will cause more problems..
I've replaced about eight F35's already at my shop, the cable could have snapped but after what you stated, it's the syncros.
FYI: if it did snapped it wouldn't fully engage into the fourth., it would grind as well..
Old Aug 29, 2012 | 01:56 PM
lazaro's Avatar
I just skip second gear in the mean while
Old Aug 29, 2012 | 08:32 PM
lazaro's Avatar
Cobalt ss shift linkage - YouTube
here is a video of the shift linkage you guys see anything?
Old Aug 29, 2012 | 10:10 PM
SSlobalt's Avatar
I forgot you had an upgraded turbo. That might cause some added stress on the tranny.
Old Aug 30, 2012 | 09:43 AM
RAIDERNATION 433's Avatar
^^^^^this^^^^^ happen to me too
Old Aug 30, 2012 | 10:42 AM
lazaro's Avatar
Can someone look at the video i posted and tell me if it looks okay.
Old Aug 31, 2012 | 09:56 PM
skip_jones's Avatar
i had the same problem with mine years ago. i made the adjustment and its been
fine ever since. i'm not saying that it isnt your syncros , but this is a fairly easy
try. check this thread i made a long time ago. bunch of pics and explanations on page
two. easy way to see if your out of adjustment is put the car in second gear, and feel between the shifter and the back of the housing (pushing straight down on the boot)
you should be able to slide your fingers between it at least. if its too close, your probably
out of adjustment.
https://www.cobaltss.net/forums/08-1...=gear+grinding
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Fearedbynone
Apr 14, 2016 03:25 AM
Jan 12, 2016 12:01 AM
biniecki
Oct 25, 2015 02:23 PM
riceburner
Oct 2, 2015 05:47 PM
