4.05 lsd
Old Feb 22, 2015 | 11:03 AM
justabalt's Avatar
4.05 lsd
having my 4.05 lsd you think it will hold the power well to the zfr set up baiscally meaning not blow my trans up? anyone have any input on this ? thanks
Old Feb 22, 2015 | 11:12 AM
63 Nova SS's Avatar
Really depends on boost ramp, driving style, and how much you get on it. Also you will need to control wheel hop as that will eat any trans. It's better than a stock lnf tranny but if you drive it like its stolen just because it's a 4.05 doesn't mean it will last.
Old Feb 22, 2015 | 11:21 AM
justabalt's Avatar
would you say recommend upgraded trans and motor mounts? thanks
Old Feb 22, 2015 | 12:10 PM
BoostedLemonPie's Avatar
That's what he said, you better upgrade those mounts and spend on a nice boost control unit or you'll be replacing the trans before you know it. Most guys even factory turbo run at least the rotates front and rear, ottp has decent price on them.
Old Feb 22, 2015 | 12:32 PM
SalvageBaltSS's Avatar
It wont last, just sell me the trans.
Old Feb 22, 2015 | 03:47 PM
63 Nova SS's Avatar
I have stock motor mounts and Powell trans mounts and rear control arm mounts and they handle it pretty well.
Old Feb 22, 2015 | 03:53 PM
blueLNFftw's Avatar
Boost ramp it.
I am about to run a ZFR on my stock trans. It will be fine. Going to boost ramp a moderate tune and get as close to 400whp as I can.
Dont boost high in the low RPMS and you should be fine.
Do not install a super grabby clutch either. You want something you can slip in.
Old Feb 23, 2015 | 02:56 AM
ae_xiong's Avatar
Originally Posted by blueLNFftw
Boost ramp it.
^^^This! I just had my 4.45 trans from Powell stripped 3rd gear. It ran perfectly fine for about 8 months until I got a new clutch (ky stage 3) and two monthes later I striped 3 gear doing a run. Is it related with the 6 puck clutch??? Idk... But just to be safe, try a different clutch?
Old Feb 23, 2015 | 02:57 AM
ae_xiong's Avatar
And don't forget a little boost ramp won't hurt no body. I learned my lesson the hard way. Lmao
Old Feb 23, 2015 | 12:48 PM
08VRSS's Avatar
Speaking from personal experience:
Stock turbo on e47: The bs myth that you will be ok if you only go WOT at high rpms and the clutch will slip before the tranny breaks = BS
my stock 3.82 let go on a 3rd gear pull starting at 3800 rpms and blew at 4800rpms with a stock clutch slipping until 4500rpms, as soon as it grabbed a bit at high rpms, BOOM.
ZFR and my 4.05 lsd swap, very small mild boost ramp, coming in full boost 25psi between 3800-4000 rpms, no issues for 18,000 miles. Ky stage 3 clutch too.
Wheel hop will kill it, driving it like a mad man racing everyone and everywhere not a good idea, rev matching on downshifts helps a lot taking a load off gears.
Oh and I'm running factory mounts too.
Old Feb 23, 2015 | 01:25 PM
footballplaya3k's Avatar
A boost control is not needed, its all in the tune.
Old Feb 26, 2015 | 08:50 AM
tomj77's Avatar
I'd would assume ur tranny blew because of ur slipping clutch. Here is what I mean. U boost at 3800, ur clutch starts slipping so not all the power is going through the trans, as soon as ur clutch grabs at full boost it would be the same thing as having no boost ramp and givin her at lower rpm cause u have all this power suddenly hitting the tranny where is wasn't when the clutch was slipping so net result is boom. I'll bet if ur clutch hadn't slipped,, and the power would have come on slower and smoother the way it should, ur tranny wouldn't have blown.
Old Feb 26, 2015 | 09:00 AM
tomj77's Avatar
My stock trans has about 100k kms on it, have changed fluid 3 times, ky clutch that slipped on Zfr at hard pulls, did a lot of hard pulls tuning for Zfr and meth. With boost ramp and starting in 3rd, at 3k rpm. It's taken the abuse so far. Now I'm on southbend stage 4 cause Zfr killed my ky clutch. Does not hold the tq it says it can. I'm hoping this new clutch don't take out my trans. It's a lot less harsh engaging than the ky. Ky fricken slammed in gear, sometimes it felt like I bounced off second gear or something when I shifted. Was aweful.
Old Mar 4, 2015 | 05:36 PM
08VRSS's Avatar
I think we all can agree anything short of 4.45s or a 6 speed swap is really hit or miss on good setups making decent power. Its really no fun wondering if you get on this time, is it going to let go. Gotta pay to play. I've pushed the block beyond its limits and the tranny too, ecotec is an amazing platform to a point. I now have dialed it back to a 93 octane tune 25psi and conservative timing (14* up top). I think i'm going to focus more on building a N/A V8 240sx drift car lol.
Jan 12, 2016 12:01 AM
HEATON
Oct 16, 2015 07:21 PM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
importkiller
Sep 30, 2015 07:18 PM
Sep 27, 2015 08:53 PM
