Is 400 HP and TQ easily obtainable?
Is 400 HP and 400 TQ easily obtainable with bolt ons and a tune?
I will be adding more questions to this thread to learn more and more.
Thank you!
What's the difference of Hahn VS ZZP?
I already have Hahn exhaust on my LNF and was wondering if I should just go Hahn everything but then I see a lot of people run ZZP...
Also! A first upgrade! Should I go intake? or upgrade the intercooler? Could I go straight ahead and get the GM Tune for 290 HP and 320 TQ with everything stock?
Go to crateenginedepot.com and get the GMS1 sensors then get a custom tune. An intake and charge piping is recommend but not needed. An intercooler would also be a nice upgrade, I believe ZZP sells the charge piping and intercooler as a kit.
Then get a custom tune, if you go HP tuners you'll get more out of the car but it'll cost more. A Trifecta tune is cheaper and most people are satisfied by them although the response time can be bad.
I'd personally go with ZZP for most of your parts, Hahn has fallen out of touch since a family member died. I believe you can only order from them by e-mail although Powell products are the same way.
If you're going to modify the suspension you have to decide what you want, low, handling or a compromise of them both. For low you're best off getting coilovers or H&R springs. For all out handling the best you can get is YYZ springs and Koni front and rear shocks/struts. Lastly a nice compromise is SSC springs. I'd also get rotated transmission mounts (either ZZP or Powell, I'd get Powell) and a rear swaybar, Powell once again. For preventative maintenance I recommend replacing the control arm bushings as at 50k miles yours are probably already going bad. Powell sells a set with a lifetime warranty and they are a great upgrade although solid Moog bushings are much cheaper but not as durable. If you really want you can also replace the rear beam bushing, recommend Powell there again.
https://www.google.com/search?q=all+...m=122&ie=UTF-8
With the GMS1 sensors, I have to take it to the GM dealership and they do the rest for me? Along with a HP tune and this lovely package?
ZZPerformance - LNF Turbo Upgrade #ZZ-LNFTBUG
I can hit my goal of 400 WHP?
and what about tires? Should I throw some E/T streets on the front and be fine?
Not easily obtainable on pump gas unless you have E.
I to this day I have no idea why people have a set goal of hp of what they want. Its completely dumbfounding people set a goal for a number compared to having something with a ton of usable power...
Sent from my Samsung Galaxy S4 using CobaltSS
I'll leave this here for you to help you understand
https://www.cobaltss.net/forums/dyno...inally-295525/
Thanks a lot SunburstSS! Wow and you have ZFR Turbo, ZZP Catted Downpipe, ZZP Full Intercooler Package and with all of that made 355 Whp / 327 Wtrq and on a conservative tune... I likey!
When purchasing the ZFR... what in the world is a "90 degree Coupler for ZZP Charge Tubes" for $35.00 more? lol
Oh thank you!
I'm a noob and need a map... lol
Hahn is over priced in a lot of stuff. stay away from their charge pipe and intake, its made of a carbon steel, its stronger than pipes made of aluminum but heavier and it rusts. more than one person on here had theirs rust. my lower charge pipe was filled with rust. go with zzp stuff rather.
400 is easily attainable on a 6758 with a good tuner on 93. note i said with a good tuner.
zzp, werks, injen, all make good charge pipes, k&n intake is really the only good option.
Like others have stated on 93 octane 400/400 will be tough, with E it's very obtainable. Why don't you research some more, buy a zfr and install it to see how you like the power before you make such a goal.
Any specific list to follow when buying mods? Such as... say charge pipe first, then inter cooler second, etc. or is there no way I can mess up with the order of bolt ons I get? lol
https://www.cobaltss.net/forums/supp...ackage-299575/
