501 whp
Here is the video, this is still on the 93 at 24 psi, I rolled on throttle going wot at around 65-70 so it wouldnt spin as bad, and got the boost dialed in a bit, about 20 psi in third and 24 in fourth. hope you enjoy. I used the gopro so thats why the video looks like it does.
2009 Cobalt SS PTE 5857 - YouTube
external dump?
night and day difference from your s252 setup @ 25psi
I'm afraid this efr 6758 is going to be too small for me. LOL.
Can tell the gearing is different too. Looks like it's better for racing, 4th seems to get you at a good point by the end.
Was your s252 kit a T4 setup? Couldn't zzp put on an efr 7064 instead of the 252? Maybe it's not that simple
Took a trip to ZZP today, did a little tuning and we were able to hit my goal of 500whp at 30 psi on 112 octane gas. Here is a pic of the chart. This is what the real world numbers are, no skewing anything to make the numbers higher, I did not want that. The correction factor alone was taking 5% of power. Car made 429whp on 93 octane at 24psi. On the conti DWS tires I have now it spins third worse than it did on the stock turbo in second. Looks like I will be getting tires next spring lol. Dont mind the wideband readings, the wideband was acting goofy all day, the logs show a nice perfectly smooth flat line. Thanks again to ZZP and Matt and Ryan especially.
thats no 4 cylinder!!!! thats a rocketship!
external dump?
Forgot the camera at home. I will get pics of the set up later on
Thank You
Last edited by cmiller8006; Oct 23, 2011 at 11:44 AM. Reason: Automerged Doublepost
