60-100 in 4.6 seconds.
#51
So Ive been tesing my 5-25 mph runs lately.....
I think termi tunes better than trifecta
#53
Rattlesnake Race Shop
I dunno. I just know that I've seen it in quite a few different threads. I might be mistaken, there could be more range involved than that... but those are the speeds that seem to stand out in my head.
3rd gear is included... but that is not all of 3rd gear.
Haha... Low end power? Yeah... right. Shows how much you know. You really do say some dumb things.
Man, those HX35 turbo's sure are great for low-end power.
#54
To answer your question from before. That is the latest Beta scanner format.
Thanks.
#55
3rd gear goes to about 95 since you dont seem to know.
I might be making a trip out to AMS which is in west chicago this spring. I can let u know ahead of time.
#56
I remember watching some Tuner Challenge thing on MTV and it was AMS vs Cristian Rado....AMS blew up their EVO in (1) 1/8th mile race LMAO! Enjoy
And you're wrong on the twin scroll nonsense you just wrote...
Not my words:
A twin scroll turbine housing uses dual side by side passages into the housing. When coupled with a pulse converter manifold that separates exhaust pulses as many crank degrees in the firing order as possible, a twin scroll or divided housing works to reduce lag, decrease exhaust manifold backpressure on the top end, reduce the potential for reversion, and increase fuel economy. The twin scroll is based off the same reasoning a tri-Y header uses: keep spent exhaust gases out of an adjacent cylinder drawing in fresh air. At high rpm on a turbo car, exhaust backpressure is usually significantly higher than atmospheric pressure, and often higher than intake manifold pressure as well. A divider between each of the two volutes allows the cylinders to expel the exhaust gases without it interfering with the fresh air for combustion. Since there are two openings, each a smaller overall volume than a single scroll design, the exhaust velocity of each pulse can be maintained. This also spins the impeller more easily because lag is a function of the scroll area. A single turbine housing opening isn't as efficient since cylinders on the exhaust stroke of the 4 stroke cycle contaminate the cylinders that are on overlap with exhaust gas. A conventional turbine housing is not as effective in using exhaust pulse energy to help spin the turbine up to speed as it does not exploit the energy contained in the pulses as well.
Not my words:
#57
http://www.amsperformance.com/ams_dragevo.php
^holding the record for both viii and ix. They must not know **** about building fast cars...
Not my words:
Not my words:
#58
Reading > You...
a twin scroll or divided housing works to reduce lag, decrease exhaust manifold backpressure on the top end...
And congrats on their records, still saw what I saw. It was the company you're thinking of because both teams used their turbo kit. Rado made more power without NO2 then AMS did with NO2. AMS then blew up the car on the 1 race of 1/8th mile.
#59
Big power comes from big turbos. The whole point of having a big turbo is because they make rediculous power and can make it to redline. The whole point of a twinscroll is to spool quick, not make big numbers. If you want big numbers, nothing is better than a big turbo, or tt in some cases.
#60
I agree. If you compare a K04 to a twin scroll K04 tho, you will find the twin will spool harder faster and hold out longer.
Another quote from elsewhere:
We have found the twin-scroll systems have higher backpressure at low rpm (which is good for turbo spool-up) and lower backpressure at high rpm (which is good for top-end performance)
#61
#63
Dude, I own a ******* evo I know where the powerband is. It has a shitty top end but tons of grunt in the low end. The only redeeming top end it has comes from the MIVEC. Without a turbo upgrade, the majority of your power in the stock turbo is bottom of the powerband because its a 2x scroll. Unless you do a big turbo upgrade or stroke the engine the dual scroll is going to hit hard and then taper off, even with a boost controller it still tapers a bit.
And no one was talking about STOCK TURBO. You made a STUPID generalized statement that "The DSM's are generally all about low end power ( depending on the build )"...
Hmmm... doesn't really sound like you are talking about Stock Turbo cars there. Especially since one of the first few upgrades that most DSM owners do, is swapping out the turbo.
Depends on your Rev Limiter, first of all. And second of all, I simply said that 70-90 wasn't all of 3rd gear... which it isn't.
I've got a log of my friend's 1g... shifted to 3rd @ 56mph (6600rpm) and then shifted to 4th at 83mph (6600rpm).
And then I have another log of a different friend's... shifted to 3rd @ 67.9mph (7928rpm) and shifted to 4th @ 101.5mph (7812mph)
As said before. You say a lot of stupid ****.
#64
#69
What's your point? Your Evo ISN'T a DSM.
If you had read, I went on to say that if theyre running a big turbo, or stroked engine OBVIOUSLY thats going to change. On a maxed out stock turbo, and out of the box, theyre better in the low end. They werent designed to be top end monsters. Didnt you ever notice how low the gearing is in them? Low end grunt. You can modify them to make better top end power, JUST like anything else. However, they dont come out of the box with a good top end, and werent designed with as much in mind.
This is what I was trying to say. Sorry, I probly should have specified better.
#72
dsm = diamond star motors... it was when chrysler owned mitsubishi... no way does dsm = mitsubishi... mitsubishi is only diamond...
hence why the 3000gt and the stealth are practically the same cars.... and the talon and eclipse??
no way is an evo dsm...
back on topic... nice to see that 4.6 term. your car pulls faster than a caterham or what ever its called lol..
#73
Ok, so I just looked up the Cobalt SS in that database and it came up with the SS/SC. It runs 9.7 seconds from 60-100 stock so a SS/TC running 8.5 seconds still seems very correct to me because we all know that a stock SS/TC will beat a stock SS/SC. I also looked up the 05 Mustang GT and it came up 8.3 seconds and most who have raced 05 and up mustangs can attest that it is a driver's race from a roll.
#74
