? about turbos
Old Mar 2, 2011 | 11:16 AM
stealthbomber87's Avatar
? about turbos
how are the turbo kits from performance autowerks compared to zzps. Can you bolt the turbo kits right up and go or do you need other stuff from performance autowerks. Are the turbos better than zzp are zzp better.Not sure what horsepwer the turbos give and spool times
Old Mar 2, 2011 | 11:22 AM
jb09ss's Avatar
2 good and well performing kits. Performance autowerks = pte billet ball bearing turbos (excellent turbos), zzp borg warner extended tip turbos, non ball bearing, excellent turbos too. When comparing the price of both kit, keep in mind that zzp use a log manifold, p-werks a tubular manifold, and the ball bearing turbos p-werks use are more expensive. You can get a journal bearing version of the kit from p-wers too, iirc.
Old Mar 2, 2011 | 11:46 AM
what software do you get to run around 430whp with the pwerks kit and are the ball bearings better than the journal kit
BartSS's Avatar
Both are great kits all depends on how much you wanna spend
Old Mar 2, 2011 | 11:50 AM
slowbalt84's Avatar
If u have the money I would go with the werks turbo kit. I'm a precision turbo guy tho lol so I'm bias. Not really a fan of journal bearing turbo either.
Old Mar 2, 2011 | 11:53 AM
Chevycobaltss3's Avatar
Yeah if you have the $ get a dual ball bearing Turbo I'm a journal Turbo. S20g and my full spool is at 3500-3800
Old Mar 2, 2011 | 11:57 AM
cmiller8006's Avatar
With the smaller size of these turbos it will not hurt to run the journal bearing turbos. They are tough as hell. I am putting a ZZP kit on my car but have a pte5857 instead of the s259et. I am putting the ballbearing on mine as well but it is not needed. You do need to run an inline oil filter for the ball bearing turbos tho, they are very picky with dirt and will lower there life span, but they also are very tough. I suggest that you go with one or the other and stick with that company, my company is obviously ZZP.
Old Mar 2, 2011 | 12:05 PM
were you get an inline oil filter and what piping should you run with the werks kit and intercooler and intake
Old Mar 2, 2011 | 12:08 PM
slowbalt84's Avatar
Pegasus auto parts
Old Mar 2, 2011 | 12:29 PM
what piping and intercooler would fit with the werks and tuning should you get
Old Mar 2, 2011 | 01:01 PM
Here is a filter. Like I said, which ever company you go with, stick with that company for everything.
EXTREME PSI : Your #1 Source for In Stock Performance Parts
Old Mar 2, 2011 | 01:18 PM
how come you cant select chevy on the sight
Supercharged06SS
Dec 11, 2022 04:47 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
patooyee
Oct 15, 2015 05:11 PM
maliki778
Oct 1, 2015 07:39 PM
