Aeroforce interceptor
Old Aug 20, 2009 | 10:16 PM
Projekt's Avatar
the PLX is WAY! beter..but also costs 400 dollars
Old Aug 20, 2009 | 10:20 PM
PrincessTurbo's Avatar
I thought the Interceptor was the same price ?
399 for a dual Interceptor .. atleast on the website it says that ?
the PLX is only 399 too
I am confused
well anyways I just looked at the PLX site and the multi OBDII doesn't even read AFR off the OBDII port ... doesn't seem like its worth it ..
Old Aug 21, 2009 | 12:22 AM
Boosted_Cobalt09's Avatar
the interceptor is an easier gauge to work with if you ask me although plx does make a nice product aswell. as for the dual cluster pod....someone on this board makes them but they are pricey. zzp makes a dual pod i think that will work with the sedan.
Old Aug 21, 2009 | 10:18 AM
CudaJoe's Avatar
Originally Posted by PrincessTurbo
I was wondering about a 3 pod for my sedan also ..
Where did you find that 2 pod at ?
I know they make one that goes in the middle of the steering colum too ..
The Coupes pillars are different I know that because thats partialy why you cant get the RPD unit
Its on the zzp website for like 80$, looks really nice, like stock but with a second slot for another guage.
Old Aug 21, 2009 | 10:57 AM
reign1's Avatar
modern performance has dual intersceptors CN type for thhe SS/TC for 350.
50 bucks off aint bad.
Old Aug 21, 2009 | 06:29 PM
orbalt08's Avatar
my pillar is from zzperformance. The quality is top notch! I would reccomend getting it from them
Old Aug 22, 2009 | 05:31 AM
SSlobalt's Avatar
You guys got any night-shots of your setups? I'm a sucker for the light shows. It's the kid in me, I guess.
Old Aug 22, 2009 | 06:15 AM
steddy2112's Avatar
Originally Posted by reign1
im pretty sure they dont.
its why so many buy wide bands and intersceptors.
No, both the regular LS, LT, SS/TC Interceptors and the SS/SC interceptors can read a wideband.
With all EXCEPT the SS/TC you have to hook one up to the interceptor.
Whereas the SS/TC one can read the factory Lambda.
Old Aug 22, 2009 | 09:40 AM
ill have to get some night pics of the triple setup. people drool at local car meets....or the number one thing i hear is " HOLY F*CK hes got 3 scan gauges!!!!!"
Old Aug 23, 2009 | 07:19 AM
SSlobalt's Avatar
Please do. I'm curious.
Old Aug 24, 2009 | 10:39 AM
  #36
reign1's Avatar
the SS/SC intersceptor it PT type. it cant read the AFR readings.
the LS, LT, and SS/TC is CN Type intersceptor that can read the AFR.
its plug and play on the SS/TC btw. it can read lambda and AFR.
plug and play
Old Aug 24, 2009 | 11:55 AM
  #37
CudaJoe's Avatar
So if I ran the stock boost guage with a Aeroforce ( I can do that right?) I would just plug the connector into a presumed second outlet under the dash?
Old Aug 24, 2009 | 12:17 PM
  #38
reign1's Avatar
the OBD2 port is a port next to ur left shin when u push in the clutch. the areoforce plugs right into there
Old Aug 24, 2009 | 12:42 PM
  #39
CudaJoe's Avatar
thanx for the info!
Old Aug 24, 2009 | 12:44 PM
  #40
reign1's Avatar
not a problem..
i need a 3 gauge pillar
  #41
HB_SS/TC's Avatar
takes like 5 minutes to install both pillar and gauges
Old Aug 24, 2009 | 12:47 PM
  #42
reign1's Avatar
what about running the wires to the battery in the back david?
ill prolly buy mind today
Old Aug 24, 2009 | 12:49 PM
  #43
HB_SS/TC's Avatar
the only thing you plug in is the OBD2 port
Old Aug 24, 2009 | 12:51 PM
  #44
Projekt's Avatar
got my 2 gauge pillar this weekend. buying my Autometer cobalt mechanical 30 psi gauge today and my interceptor should be waiting at the parcel service when i go get my rims.
wewt wewt
anyone know if our ECU (or interceptor) displays oil pressure levels?
Old Aug 24, 2009 | 12:53 PM
  #45
reign1's Avatar
im pretty sure it does..
aeroforce website was saying u had to run it to a 12V battery source. lol
Old Aug 24, 2009 | 01:19 PM
  #46
orbalt08's Avatar
The CN type for our cars only need to be plugged into the obd2 port. no need for seperate wiring for to the battery. seriously a 5 minute instal
Old Aug 24, 2009 | 01:20 PM
  #47
reign1's Avatar
sweeeeeeeet
Old Aug 24, 2009 | 01:39 PM
  #48
Projekt's Avatar
thats not true, the older types ran off a power line. the newer ones run off of OBD2 power.
Old Aug 24, 2009 | 01:54 PM
  #49
orbalt08's Avatar
Well the ones i bought didn't need extra power
Old Aug 24, 2009 | 08:53 PM
  #50
for the 08 and 09 cobalts they DO NOT need to be wired. just plug them in. they sometimes take a minute or 2 to turn off but they eventually will turn off by themselves.
