Aeroforce interceptor
Old Aug 20, 2009 | 02:06 PM
CudaJoe's Avatar
Soooo.... How do this thing work/ Does it work with the 2008-2009 Cobalt SS? Do you need a second bunge off the downpipe? Does it base all its calculated data off the emissions? What would be the best way of looking stock while getting a second guage?
Old Aug 20, 2009 | 02:20 PM
orbalt08's Avatar
It will work with the 08/09's you just have to get the right one. I have 2 setup along with the stock boost gauge on a triple pillar. I made a how to. It's really simple to setup and it reads a ton of different data. There are a few threads on what it reads for the LNF. I can't remember what everyone of them are. It's a pretty long list
Old Aug 20, 2009 | 03:13 PM
CudaJoe's Avatar
oh ok cool, I'll try to search for your "how to" How much did it end up costing parts wise? I would probably just get a dual pillar so long as the color matches the stock color.
Old Aug 20, 2009 | 03:14 PM
Projekt's Avatar
pretty sure the SS/TC has a factory wideband.
Old Aug 20, 2009 | 03:16 PM
reign1's Avatar
hey if the interceptors could tap into the wideband reading. that would be awesome.
but if not. looks like a wideband and intersceptor will go into a 3 gauge pillar for me.
yupp yup it does
Old Aug 20, 2009 | 03:20 PM
Projekt's Avatar
so the interceptor will read AFR with the OBD2 port
Old Aug 20, 2009 | 03:22 PM
CudaJoe's Avatar
ok cool just saw your "do it yourself" and I got a question, how come you got dual areoforce guages? Is it so you can display two display two different sets of data like AFR's and AIT's without messing around with programming them? How do you switch between different data readings on one guage? Is I need to get home from work so I can see a picture of this bad boy!
Old Aug 20, 2009 | 03:26 PM
reign1's Avatar
has buttons on the front to change the info. but some like to see more than just 2 readings. so they buy 2. and get 4 readings.
idk if anyone has tapped their wideband into the intersceptor yet projekt
Old Aug 20, 2009 | 03:31 PM
Projekt's Avatar
im pretty sure all the interceptors display AFR
if not. i just wasted 160 bucks
Old Aug 20, 2009 | 03:33 PM
reign1's Avatar
im pretty sure they dont.
its why so many buy wide bands and intersceptors.
Old Aug 20, 2009 | 03:34 PM
CudaJoe's Avatar
ok cool again. Last thing then I gotta get home. lol. If I were to get the two guages, I'd only be able to but one in the A-pillar while the other has the stock guage.
It looks like they only make a dual meter A-pillar for the sedan SS. (which is what I have) Do you think the triple A-pillar would fit in a sedan?
I'd really like to keep the stock boost guage in, but getting two interceptors for that price they list is pretty good!
Old Aug 20, 2009 | 03:43 PM
Projekt's Avatar
ive never heard of a ss/tc owner buying a wideband
Old Aug 20, 2009 | 04:41 PM
reign1's Avatar
HB SS/TC has one.
this is so confusing.
Old Aug 20, 2009 | 04:50 PM
steven6870's Avatar
Interceptors read AFR on TC. BTW if you run 2 you can split into the OBD, or buy the actual splitter to make it easy.
Old Aug 20, 2009 | 04:52 PM
reign1's Avatar
positive? pics or ban!!!
Old Aug 20, 2009 | 04:57 PM
steven6870's Avatar
https://www.cobaltss.net/forums/show...=aeroforce+afr
I dont have it, but IsIt Fast does...with pics I <3 Search, lol.
Old Aug 20, 2009 | 05:03 PM
reign1's Avatar
search>me
thanks for the info
i <3 you
no homo.
lol
Old Aug 20, 2009 | 05:49 PM
orbalt08's Avatar
The interceptors read AFR, Lamda and a crap ton of others. I have 2 so that I can keep an eye on 4 things at once. The cool thing about the interceptors is that you can have it cycle through whatever parameters you want it to, so that it won't just show 2 things at a time. It will show 2, then a couple seconds later show 2 more, and so on and so on.
Old Aug 20, 2009 | 06:11 PM
hallss's Avatar
so which interceptor do we need for the tc?
Old Aug 20, 2009 | 06:18 PM
orbalt08's Avatar
I believe it's the CN type. I know for a fact that it is NOT the one that works for the SC
Old Aug 20, 2009 | 07:04 PM
Boosted_Cobalt09's Avatar
it is the CN type interceptor. also the big plus on the tc vs the sc is you dont have to wire these to a power source like i believe the instructions say on the sc and redline. im currently running 3 interceptors(without factory boost gauge).....sick setup for me lol. i was the first one on here to have it.
Old Aug 20, 2009 | 09:48 PM
PrincessTurbo's Avatar
I was wondering about a 3 pod for my sedan also ..
Where did you find that 2 pod at ?
I know they make one that goes in the middle of the steering colum too ..
The Coupes pillars are different I know that because thats partialy why you cant get the RPD unit
Old Aug 20, 2009 | 09:54 PM
Projekt's Avatar
i won i knew i was right!!!
Old Aug 20, 2009 | 10:11 PM
PLX devices
OBD-II guages http://www.plxdevices.com/multigauges.html VS
http://www.aeroforcetech.com/products_order_gm.html
Now I know they have the middle guage holder thing but I can't find it !
I kind of want the PLX devices
Old Aug 20, 2009 | 10:13 PM
orbalt08's Avatar
I've never heard of the PLX devices. They look different
