Aeroforce interceptor question
Old Oct 5, 2008 | 05:26 AM
steddy2112's Avatar
Can this read AFR?
If so, is it as simple as plugging the damn thing in?
Old Oct 5, 2008 | 05:37 AM
DeftonesFan867's Avatar
I would assume so, and oh yeah sorry for taking off earlier, but ***** were present..
Old Oct 5, 2008 | 04:57 PM
Kage's Avatar
Originally Posted by steddy2112
Can this read AFR?
Yes is will. Yes it is.
Simple as that.
Old Oct 5, 2008 | 05:10 PM
lecznar1's Avatar
i don't think it does but the interceptor has 2 aux inputs that u can make it read a/f ratio if you would like.. i am probably going to get a pair of these for my 08 and i looked into the a/f ratio on it and that is what i found... of course if i am wrong someone is welcome to correct me :^)
Old Oct 5, 2008 | 05:28 PM
Kage's Avatar
In a normal case this would be true. BUT in are case we have a stock wide band so the gauge will read the numbers from the OBD2 port.
Old Oct 5, 2008 | 05:54 PM
steddy2112's Avatar
Sweet.
May have to obtain some. Thanks.
Old Oct 5, 2008 | 05:57 PM
DoMiStIc_RuSh_06's Avatar
Its just the turbo ss that have the stock wideband right?
Old Oct 5, 2008 | 06:00 PM
steddy2112's Avatar
Yes.
Old Oct 5, 2008 | 06:01 PM
wells that sucks lol...
Old Oct 5, 2008 | 07:13 PM
lecznar1's Avatar
nice that's even better lol the only other question i had was if i was to put like a triple pod pillar, wouldn't it mess with the side airbags?
Old Oct 5, 2008 | 08:01 PM
JPizzle's Avatar
Nope!
Old Oct 5, 2008 | 10:24 PM
lecznar1's Avatar
good **** i got worried cuz i didnt wanna put one on there and then have the airbag come out and blast me in the face lol
and kage do u have any pics of ur pillar set up? thats exactly what i wanna do to mine i would like to see how it looks if u get a chance
Old Oct 5, 2008 | 10:25 PM
BLAZIN07SS's Avatar
I'm too JDM for you
as far as i am aware you need to buy a lambda cable in order for the Interceptor to read wideband which is like 200 bucks
Old Oct 5, 2008 | 11:19 PM
Kage's Avatar
I have just what came with it (the cable to connect them to the OBD2 port). It is reading it just fine and is showing the same numbers as HPT showed when it got tuned.
Old Oct 5, 2008 | 11:29 PM
BLAZIN07SS's Avatar
I'm too JDM for you
damn you TC guys. lol cool!
Old Oct 6, 2008 | 02:10 AM
IsItFast?'s Avatar
Yes and Yes! NO cables needed other than plug it in and GO. Read my post here - I was the first 2008 Cobalt SS with Interceptor gauges!
Sensors that work:
IAT1
IAT2
Ambient
Coolant
Catalytic Converter Temp
RPM
Boost
MAP KPA
MAF lb/m
MPH
Throttle Percent
Ignition Advance
Short Trm B1
Long Trm B1
Engine Load
Rail Pressure (BTW its around 550psi at idle FYI)
HP
Run Time
Barometric Pressure
Battery Voltage
Lambda
A/F ratio (YES it is a wideband)
MAF Frequency 1
Fuel
O2 B1S2
Oil Temp
instant MPG\MPG average
Misfires
Resetting the long term fuel works from the menu.
Resetting and reading CEL works
Fan controls (high and low) works
performance gauge works (measures 0-60, 1/8th mile, 1/4 mile times and MPHs)
Probably work but don't know how to test:
o2 current
ABS Throttle Pos
Knock 1
Does not work:
Fuel trim cell
A/F cmd
OIL PRESSURE (Damnit GM (and others), why cant you spend the extra few dollars on a simple sensor?)
Trans temp and basically all the sensors related to an automatic transmission (obviously). Maybe this works when the cobalt comes out with the auto.
Here is a pic installed in my car of the 3 gauge pillar
Old Oct 6, 2008 | 02:17 PM
lecznar1's Avatar
that looks sick man nice job.... where did u get the pillar from?
Old Oct 6, 2008 | 04:50 PM
peachpuff's Avatar
How many sets of eyes do you have, thats a lotta stuff to look at
Old Oct 6, 2008 | 07:10 PM
IsItFast?'s Avatar
I think it was an eBay special - I dont remember. Pillars made for the 07 and earlier fit. (this was advertised as one for an 06)
I also have my radar detector (off screen)
Old Oct 6, 2008 | 08:20 PM
lecznar1's Avatar
ok cool i am going to probably get some of those
Sl0wbaltSS
Nov 21, 2018 11:11 PM
ineedacobaltss
Nov 7, 2015 02:25 PM
brandon04
Oct 21, 2015 07:04 AM
nathan112i
Sep 30, 2015 07:12 PM
