Aeroforce interceptor question
i don't think it does but the interceptor has 2 aux inputs that u can make it read a/f ratio if you would like.. i am probably going to get a pair of these for my 08 and i looked into the a/f ratio on it and that is what i found... of course if i am wrong someone is welcome to correct me :^)
good **** i got worried cuz i didnt wanna put one on there and then have the airbag come out and blast me in the face lol
and kage do u have any pics of ur pillar set up? thats exactly what i wanna do to mine i would like to see how it looks if u get a chance
Yes and Yes! NO cables needed other than plug it in and GO. Read my post here - I was the first 2008 Cobalt SS with Interceptor gauges!
Sensors that work:
IAT1
IAT2
Ambient
Coolant
Catalytic Converter Temp
RPM
Boost
MAP KPA
MAF lb/m
MPH
Throttle Percent
Ignition Advance
Short Trm B1
Long Trm B1
Engine Load
Rail Pressure (BTW its around 550psi at idle FYI)
HP
Run Time
Barometric Pressure
Battery Voltage
Lambda
A/F ratio (YES it is a wideband)
MAF Frequency 1
Fuel
O2 B1S2
Oil Temp
instant MPG\MPG average
Misfires
Resetting the long term fuel works from the menu.
Resetting and reading CEL works
Fan controls (high and low) works
performance gauge works (measures 0-60, 1/8th mile, 1/4 mile times and MPHs)
Probably work but don't know how to test:
o2 current
ABS Throttle Pos
Knock 1
Does not work:
Fuel trim cell
A/F cmd
OIL PRESSURE (Damnit GM (and others), why cant you spend the extra few dollars on a simple sensor?)
Trans temp and basically all the sensors related to an automatic transmission (obviously). Maybe this works when the cobalt comes out with the auto.
Here is a pic installed in my car of the 3 gauge pillar
Sensors that work:
IAT1
IAT2
Ambient
Coolant
RPM
Boost
MAP KPA
MAF lb/m
MPH
Throttle Percent
Ignition Advance
Short Trm B1
Long Trm B1
Engine Load
HP
Run Time
Barometric Pressure
Battery Voltage
Lambda
MAF Frequency 1
Fuel
O2 B1S2
Oil Temp
Misfires
o2 current
ABS Throttle Pos
Knock 1
Does not work:
Fuel trim cell
A/F cmd
I think it was an eBay special - I dont remember. Pillars made for the 07 and earlier fit. (this was advertised as one for an 06)
I also have my radar detector (off screen)
Sl0wbaltSS
Nov 21, 2018 11:11 PM
