Amount of Boost does NOT kill Map Sensors
Old Jun 11, 2011 | 01:18 PM
SSlobalt's Avatar
I just bought some spare MAP from IamBroke so that I can clean/swap them out every oil change, now. Trying to get rid of some of these gremlins that make my car run weaker on some days by preventative maintenance.
Old Jun 11, 2011 | 02:56 PM
Baron7700's Avatar
there 15 bux from CED
Old Jun 11, 2011 | 03:06 PM
Black08SSTC's Avatar
correct, i was one of the first people to get BYT tuned and he realized that after i replace the 3rd or 4th map sensor that this was the cause. Definitely invest in a catch can or something. Cant wait till i can get another cobalt to toy with !!!
Old Jun 11, 2011 | 03:16 PM
09CobaltSS1's Avatar
^^ you're looking to purchase another cobalt after you just sold your a few months back??
Old Jun 11, 2011 | 04:47 PM
BYT*SS*TURBO's Avatar
Thats how he rolls lol. He bought/sold mods like crazy, so why not cars too lol
Old Jun 11, 2011 | 04:54 PM
talk about a glutton for punishment..
Old Jun 12, 2011 | 12:21 AM
not right now, but in a year or so maybe. i truly miss having a fun car like that. It was awesome, My new project, a 1999 crown vic which im attempting to procharge should be fun though
eh you only live once lol
Last edited by Black08SSTC; Jun 12, 2011 at 12:21 AM. Reason: Automerged Doublepost
Old Jun 12, 2011 | 09:56 AM
bcuree's Avatar
When you talk about running the stock maf, are you refering to the 2 bar or the gm upgrade?
Old Jun 12, 2011 | 10:24 AM
neither.. MAF, MAP. what's the difference?
Old Jun 12, 2011 | 11:10 AM
Sweetsandman's Avatar
Nothing. I run MAFs where my MAPs were and vice versa. My car runs better that way.
Old Jun 12, 2011 | 11:16 AM
  #36
the maf, 2.5bar maps, and 3bar upgraded maps are 3 different things here so let me clear up your confusion
There is no "upgrade" to the stock maf.. it is what it is. However it should absolutely be cleaned periodically as well with an electic parts cleaner.
The 2.5bar maps are the sensors mainly in question here. People were/are having issues with blowing the stock map sensors, especially when tuned, mainly due to oil blowby getting over the sensor skewing the pessure signal back to the ecm. This can generally be resolved 2 ways.. either by regularly maintaining the sensors with an electric parts cleaner, or others have seemed to have luck with installing a catch can.
The 3bar maps included in the GM upgrade kit are also just as prone to this same oil residue issue if not properly maintained the same way as mentioned above for the 2.5bar stock sensors
Old Jun 12, 2011 | 11:39 AM
  #37
bcuree's Avatar
Sorry I miss typed it, I meant map not maf.
Old Jun 12, 2011 | 12:52 PM
  #38
YelloEye's Avatar
Stock tune and motor, down one MAP sensor in the intake manifold. Oily residue was found on and inside of it, replaced sensor. Would spraying the "dead" sensor with the MAF cleaner spray fix it? If so I'll start doing the oil change swap out.
Old Jun 13, 2011 | 10:03 PM
  #39
09BlueBaltSS's Avatar
Ive been running 24-25 psi for almost 20k miles now without a sensor malfunction. I just upgraded my lower charge pipe and intercooler over the weekend and I apparently have 0 blow by. The inside of the charge pipe and inlets to the stock intercooler were so dry it had a chalky appearance. Nick speaks tha troof
Old Jun 14, 2011 | 01:37 AM
  #40
CrystalRedSS's Avatar
So would a bad MAP sensor cause my RPD to read Data Not Available every now and again? I have GMS1 and I've read on here that there was a bad batch of Bosch sensors right around the time I bought the kit. A lot of ppl on here say the lower MAP sensor is the culprit. This true?
Old Jun 14, 2011 | 01:46 AM
  #41
M-Dub's Avatar
So please stop posting that anything over 22-23psi will kill them, it's just not true. I, and a couple other people now, have run 30psi thru the OEM sensors and they hold up just fine. The only difference is they don't read accurately passed the 22-23psi.
The reason people are blowing Map sensors is from Oil Blowby. Ive seen plenty of these come now and everytime that has been the issue. If you keep blowing them, install a catch can and it will go away. Even people with GMS1 sensors have had this issue lately.
If you are someone that keeps blowing them, next time remove it and look inside the sensor, you will see some oily residue inside there. This seems to eat the inside of the sensor and cause it to fail. You can also remove them occasionally and clean them with either MAF sensor cleaner spray OR Electronic parts cleaner spray.
Thanks
Agree'd.... 30psi now for 5k miles an still on stock sensors
Old Jun 14, 2011 | 11:23 AM
  #42
I used to get that when I was on the trifecta tune. Its gone away since switching
Old Jun 14, 2011 | 11:36 AM
  #43
If you are making over 24psi and you hold that amount for more then 3 seconds, it will blank out the RPD. This can also happen tho when the MAP sensor blows.
Old Jun 16, 2011 | 11:10 PM
  #44
This only happens periodically so is that a sign of a loose connection or the sensor slowly shitting the bed, or both?
Old Jun 17, 2011 | 10:38 AM
  #45
Its just the way you are doing the pull. If you run out 1-3 like at the track, it will never happen. If you do a 3rd gear pull from 2500ish and hold over 24psi, it will blank out. Try it
Old Aug 25, 2011 | 10:39 AM
  #46
vahdyx's Avatar
So the only point of 3bar is to read boost correctly after 23psi?
So I boost at 23psi but due to my altitude I spike up to 25 often. Is it wise for me to get 3bar?
I guess I'll buy MPx Oil Catch can
Old Aug 25, 2011 | 12:30 PM
  #47
Knightwolf's Avatar
I only boost spike to 23-24 and hold about 21-22 psi; blown map sensor at 25k miles... Time to buy a catch can I suppose
Old Aug 25, 2011 | 02:07 PM
  #48
SSlobalt's Avatar
I think the term, "blown MAP" is where all the confusion is coming from. How about "gunked-up MAP?"
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
jmelton327
Sep 26, 2015 10:04 PM
