Another reason to use T-bolt clamps ONLY
Old May 29, 2010 | 01:02 AM
IsItFast?'s Avatar
Ive had the hahn charge piping on my car since the day they were available. (BTW fitment was bad, almost as bad as the exhaust, I wont be buying any more hahn products).
When I purchased them I asked the person I spoke with who stated "you dont need the tbolt clamps, our worm clamps work just fine". Well thanks to that advice, I have a dent in my hood from the first time they blew off (about 6 months ago).
At that time I bought all the 2.5" tbolt clamps available locally, and replaced all of them on the hot side but didn't have enough to do the cold side. Haven't had any more issues from there. However, since I never got around to replacing the cold side.... BLAM. after almost 30k miles with the cheap-ass hahn-recommended worm clamps on the cold side, the pipe blew off. This time it sheared off my A/C pressure switch - goodbye A/C.
So the bottom line is, NEVER EVER EVER use worm clamps. Ask anyone that has a turbo setup and they should tell you the same.
Old May 29, 2010 | 01:40 AM
D-mac's Avatar
Sucks to hear about the issues man
I just bought a Hahn CP setup from OTTP
Do you know how many of each and what size T-bolts i need to order?
Old May 29, 2010 | 01:43 AM
IsItFast?'s Avatar
Yeah, most of the clamps are 2.5" except for one 2.75" inch one on the actual throttle body.
I re-used the stock t-bolt clamps from the stock piping for some of it (turbo outlet to piping), but I purchased (total) 10 - 2.5" clamps and 2 (only used 1 but they came in pairs) 2.75" one.
Old May 29, 2010 | 01:45 AM
northvibe's Avatar
ya when i ordered my injen charge pipe I got tbolt clamps extra and new silicone couplers. tbolts ftw. I only know the wiring for the lower tmap sorry.
Old May 29, 2010 | 02:11 AM
Boosted_Cobalt09's Avatar
yeah worm clamps shouldnt be used on anything except for small things. hell ive blown t bolts off on my camaro before which resulted in getting everything welded and having couplers only where its absolutely neccisary.
Old May 29, 2010 | 02:21 AM
Dr.Balt407's Avatar
yea i got the heads up on the warm clamps and i went ahead and bought all tbolts and not one clamp has blown off yet, even at 22psi.
Old May 29, 2010 | 08:09 AM
Wangspeed's Avatar
Not even stock has normal worm clamps. We have nice constant torque clamps.
Old May 29, 2010 | 11:39 AM
Terminator2's Avatar
The one of the throttle body is a worm clamp stock. I still have a worm clamp at the throttle body but T-bolts everywhere else.
Old May 29, 2010 | 12:21 PM
kidcrash603's Avatar
I've been running 23psi for 12000 miles on Dejon piping.... with worm clamps. As long as you have good quality worm clamps and understand how to tighten them properly and not strip them, you are fine. Most of the ones i've seen come off are ones that people tightened to the point of stripping the clamp or where the clamp had started to twist due to over tightening.
Old May 29, 2010 | 12:24 PM
DjJoeski87's Avatar
We need to start a dented hood club/pics thread
i just joined the club last week.. ******* injen
Old May 29, 2010 | 12:29 PM
Spooled's Avatar
What size t-bolt clams are used for the turbo inlet part 2''?
Old May 29, 2010 | 12:31 PM
DjJoeski87's Avatar
Yea*------
Old May 29, 2010 | 01:42 PM
efactor's Avatar
I'm using 2.0 and 2.5 regular clamps on my injen (hotside) CP for my LNF, except when you try to connect the lower piece to the intercooler is when the t-bolt clamps come in handy. Drove 2000 miles without my pipe blowing off or causing any vibration.
Old May 29, 2010 | 08:46 PM
SSturb's Avatar
And on a side note - anyone know which wires on our switch I can jumper to temporarily get my A/C working while I wait on the new part? Apparently this switch is a high/low switch, and has 3 wires. I don't have a wire diagram to look at.
ya i think hahn is more about quantity more than quality IMO
Old May 29, 2010 | 08:51 PM
mkulrey13's Avatar
Lame. Mine blew after 3 mins of driving haha. This time i got silcone couplers and tbolts.
Old May 29, 2010 | 09:12 PM
D-mac's Avatar
What are you tightening the T Bolt clamps to?
Torque spec the same for all of them?
Old May 30, 2010 | 04:49 AM
mkulrey13's Avatar
Ive just tighten mine till there ******* tight
Old May 30, 2010 | 10:11 AM
importkiller's Avatar
I put t-bolts on my injen cp and have not looked back. It is not worth the gamble for 10-20 bucks for a bunch of good t-bolts.
Old May 30, 2010 | 11:59 PM
redstarpa69's Avatar
I've got all of my t/c stuff from siliconeintakes.com
2.5" $2.60 each
2.75" $2.60 each
they're still on since feb 09' - not a single problem - great quality - stainless steel.
Old May 31, 2010 | 12:06 AM
D-mac's Avatar
Thats where im going to order mine
11 2.5 ones
1 2.75 one
Sound right for the Hahn kit
Old May 31, 2010 | 02:08 AM
Another trick is to use your ladies hairspray inside the silicone to help bond it to the metal. Trust me it works great!
Old May 31, 2010 | 03:52 PM
SSLOW's Avatar
subd
Old May 31, 2010 | 11:37 PM
did the hairspray trick on my GN, works great but make sure it's fully dry before you start your motor up.. hairspray is flammble..
but it suxs when you have to take the **** apart its a pita.. Orange GUNK cleans it out..
11 2.5 ones
1 2.75 one
its 15x2.5", 2x2.75" (throttle body and the K&N Air filter) and get 2 extra 2.5 "just in case"
Last edited by redstarpa69; May 31, 2010 at 11:40 PM. Reason: Automerged Doublepost
Old Jun 1, 2010 | 01:51 PM
julius41282's Avatar
EXACTLY! Tighten them down till the vein in your head starts to bulge...then you should be good...
Old Jun 1, 2010 | 02:00 PM
Berto09ss's Avatar
2.5" $2.60 each
2.75" $2.60 each
so if i got 2.5 piping should i get the 2.5 clamp??
